[Swift-devel] execution.retries
lixi at uchicago.edu lixi at uchicago.edu
Wed Jun 11 16:02:04 CDT 2008
>Hmm?
>2008-06-10 10:47:27,429-0500 DEBUG
WeightedHostScoreScheduler Releasing
>contact 7
>2008-06-10 10:47:27,430-0500 INFO
WeightedHostScoreScheduler Sorted:
>[OSG_LIGO_MIT:21.822(51.667):2/4]
>2008-06-10 10:47:27,430-0500 DEBUG
WeightedHostScoreScheduler Rand:
>15.78147400479908, sum: 100.07797485652034
>2008-06-10 10:47:27,431-0500 DEBUG
WeightedHostScoreScheduler Next
>contact: OSG_LIGO_MIT:21.822(51.667):2/4
>That seems to be your only contact. Running
>cat /home/lixi/newswift/latest/score/3500/workflowtest-
20080610-1045-58kc7p6f.log|grep "Next contact:
OSG_LIGO_MIT"|wc
>produces: 4376   30632  469760
>So there's 4376 site selections there.
>If you remove the |wc you can see the evolution of the
score.
>You only seem to have one site there. Re-trying means full
re-scheduling
>(so maybe another site if there is one).
>There isn't much marking the start of a try besides the
scheduler
>allocating a site. The successful end of a try is
represented by
>"JOB_END". Failed -> "APPLICATION_EXCEPTION".
Thanks, I see. :)
However, there is another question. Please check my another
log file on CI /home/lixi/newswift/test1/workflowtest-
20080611-0956-z09bzjs5.log. In that file:
2008-06-11 09:56:33,899-0500 DEBUG TaskImpl Task
(type=FILE_OPERATION, identity=urn:0-0-1-1213196193768)
setting status to Submitting
2008-06-11 09:56:35,823-0500 DEBUG TaskImpl Task
setting status to Submitted
setting status to Active
2008-06-11 09:56:35,877-0500 DEBUG TaskImpl Task
setting status to Completed
WeightedHostScoreScheduler multiplyScore(GLOW:-0.010
(0.994):1/2, 0.01)
2008-06-11 09:56:35,878-0500 DEBUG
WeightedHostScoreScheduler Old score: -0.010, new score:
0.000
2008-06-11 09:56:35,878-0500 INFO  LateBindingScheduler Task
Completed. Waiting: 0, Running: 0. Heap size: 12M, Heap
free: 1M, Max heap: 63M
2008-06-11 09:56:35,885-0500 DEBUG
WeightedHostScoreScheduler multiplyScore(GLOW:0.000
(1.000):1/2, -0.2)
WeightedHostScoreScheduler Old score: 0.000, new score: -
0.200
2008-06-11 09:56:35,896-0500 DEBUG TaskImpl Task
(type=FILE_TRANSFER, identity=urn:0-0-1-1213196193771)
2008-06-11 09:56:35,897-0500 DEBUG TaskImpl Task
2008-06-11 09:56:36,129-0500 DEBUG TaskImpl Task
WeightedHostScoreScheduler multiplyScore(GLOW:-0.200
(0.889):1/2, 0.2)
WeightedHostScoreScheduler Old score: -0.200, new score:
0.000
2008-06-11 09:56:36,129-0500 INFO  LateBindingScheduler Task
free: 2M, Max heap: 63M
2008-06-11 09:56:36,130-0500 DEBUG
(1.000):1/2, -0.2)
0.200
2008-06-11 09:56:36,131-0500 DEBUG TaskImpl Task
(type=FILE_TRANSFER, identity=urn:0-0-1-1213196193773)
2008-06-11 09:56:36,345-0500 DEBUG TaskImpl Task
(0.889):1/2, 0.2)
0.000
2008-06-11 09:56:36,346-0500 INFO  LateBindingScheduler Task
2008-06-11 09:56:36,347-0500 DEBUG
(1.000):1/2, -0.01)
0.010
2008-06-11 09:56:36,348-0500 DEBUG TaskImpl Task
(type=FILE_OPERATION, identity=urn:0-0-1-1213196193775)
2008-06-11 09:56:36,378-0500 DEBUG TaskImpl Task
(0.994):1/2, 0.01)
0.000
2008-06-11 09:56:36,378-0500 INFO  LateBindingScheduler Task
2008-06-11 09:56:36,379-0500 DEBUG
(1.000):1/2, -0.01)
2008-06-11 09:56:36,380-0500 DEBUG
0.010
2008-06-11 09:56:36,380-0500 DEBUG TaskImpl Task
(type=FILE_OPERATION, identity=urn:0-0-1-1213196193777)
2008-06-11 09:56:36,408-0500 DEBUG TaskImpl Task
(0.994):1/2, 0.01)
0.000
2008-06-11 09:56:36,409-0500 INFO  LateBindingScheduler Task
2008-06-11 09:56:36,410-0500 DEBUG
(1.000):1/2, -0.01)
0.010
2008-06-11 09:56:36,410-0500 DEBUG TaskImpl Task
(type=FILE_OPERATION, identity=urn:0-0-1-1213196193779)
2008-06-11 09:56:36,437-0500 DEBUG TaskImpl Task
(0.994):1/2, 0.01)
0.000
2008-06-11 09:56:36,437-0500 INFO  LateBindingScheduler Task
2008-06-11 09:56:36,441-0500 INFO  vdl:initshareddir END
host=GLOW - Done initializing shared directory
It seems that there are multiple FILE_ OPERATION and
FILE_TRANSFER for the same job when initializing shared
directory, what does this mean?
