[Swift-devel] Re: remote file system
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Jun  9 11:56:18 CDT 2008
On Mon, 2008-06-09 at 16:45 +0000, Ben Clifford wrote:
> actually specifically the sites that Xi has been using look fairly flakey
> - they often won't accept gridftp connections (as in, the site that just
> worked with fork for me now doesn't work at all).
> From the perspective of Xi's work, I think that means that this site
> should be regarded as "broken" even when it does happen to accept gridftp
> transfers and job submissions.
> Perhaps that unable to link input file error, when used on a
> known-to-be-good workflow, should always be treated for now (in Xi's work)
> as an indication that the site is not broken.
I'd say this is exactly why the scheduler keeps tabs on sites.
I also think, given that I've seen no indication in the past 5 years
that the minimum reliability of sites has increased significantly, that
we should make sure Swift works despite the occasional broken site.
> Separately, from an OSG operations perspective, someone (I guess me) could
> contact the site admin and see what is going on.
