On Sun, 2008-06-08 at 15:52 +0000, Ben Clifford wrote: > how much is the source file format and java-library linking changed? (as > in how likely is it than an existing .kml file, such as one generated by > the Swift compiler, and calling out to Java libraries such as the Swift > runtime libraries, will work?) > Likelihoods: 0 and 0.
