[Swift-devel] Re: scheduler foo
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Jul 29 19:42:40 CDT 2008
On Tue, 2008-07-29 at 19:35 -0500, Mihael Hategan wrote:
> I put that in. This should be easier to debug and understand.
> The problem, however, seems to be that wonky causes, after a while, the
> score to go to the minimum which in turn causes delays in the order of
> thousands of seconds. I need to figure out why this is happening,
> because I don't think it should.
Hmm. So if I change max load to be a constant 32, things seem to go
fine.
