[Swift-devel] Analysis of wrapper.sh
Zhao Zhang zhaozhang at uchicago.edu
Tue Jul 29 12:02:26 CDT 2008
Hi, All
I made this analysis of wrapper.sh. Correct me, if there is anything
wrong. Thanks.
zhao
SWIFT phase: When swift is started, it creates a directory with the
workload name and a random string, something like
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc
                                                        |____info
                                                        |____kickstart
                                                        |____shared
|____wrapper.sh
|____seq.sh
                                                        |____status
WRAPPER.SH phase
In my test case, the BGexec received a task in such a format
"shared/wrapper.sh sleep-l5clzzvi -jobdir l -e /bin/sleep -out
stdout.txt -err stderr.txt -i -d  -if  -of  -k  -a 600"
with the working dir "/home/zzhang/swift/sleep-20080724-1527-qakbkkcc"
WORKING_DIRECTORY                                                 OPERATION
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            OPEN wrapper.log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            CHECK if
jobid ($1, sleep-l5clzzvi ) is empty    ----> empty exit with 254
                                         V
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Get -jobdir
as $JOBDIR
-jobdir ( l )is empty      ----> empty exit with 254
                                         V
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            mkdir -p
$WFDIR/info/$JOBDIR   (mkdir
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc/info/l )
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            rm -f
"$WFDIR/info/$JOBDIR/${ID}-info" ( make a clean $ID-info file
ID=sleep-l5clzzvi )
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            openinfo
                       ( openinfo
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc/info/l/sleep-l5clzzvi-info)
                      creating log file
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT
"LOG_START" into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT "Wrapper"
into log
$WFDIR/status/$JOBDIR (create status parent dir for the job "mkdir -p
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc/status/l ")
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PARSE the
arguments
                     ( EXEC=/bin/sleep, STDOUT=stdout.txt,
STDERR=stderr.txt, STDIN=NULL,
                        DIRS=null, INF=NULL, OUTF=NULL, KICKSTART=NULL)
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Check if
there are arguments after -a  ----> empty exit with 254
                                         V
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            change $@
from "-a 600" to "600"
"$SIWFT_JOBDIR_PATH" is NULL ----> NO, local copy
                                         V
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            YES, shared
file system. DIR=jobs/$JOBDIR/$ID ( DIR=jobs/l/sleep-l5clzzvi )
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            set PATH
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT all
arguments into log
"CREATE_JOBDIR" into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            mkdir -p $DIR
(In the working dir, "mkdir -p jobs/l/sleep-l5clzzvi ")
"mkdir" is successful  ----> NO, exit with 254
                                         V
                     YES, put "Created job directory : $DIR" into log
"CREATE_INPUTDIR" into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Created all
subdirs in $DIR as in $DIRS ( create the same tree in
jobs/l/sleep-l5clzzvi as in input file dir)
"LINK_INPUTS" in to log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            CHECK file
system type  ----> local disck, cp all files in $PWD/shared to $DIR
                                         V
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            shared file
system, create links in  $DIR for all files in $PWD/shared
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT "EXECUTE"
into log
"kickstart is enabled" ----> yes, use kickstart to run the job
                                         V
                     NO, run the job with wrapper.sh
"EXECUTE_DONE" into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT "Job ran
successfully" into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            CHECK if the
out put dir tree is the same as the one in $OUTF ----> NO, exit with 254
                                         V
                    YES, COPY all output files in $DIR back to $PWD/shared
"RM_JOBDIR" into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            rm -rf $DIR
("rm -rf jobs/l/sleep-l5clzzvi ")
"TOUCH_SUCCESS" into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            touch
status/${JOBDIR}/${ID}-success ( touch status/l/)sleep-l5clzzvi-success )
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT "END"
into log
/home/zzhang/swift/sleep-20080724-1527-qakbkkcc            closeinfo
