[Swift-devel] Problems running coaster
Michael Wilde
wilde at mcs.anl.gov
Mon Jul 28 13:37:38 CDT 2008
On 7/28/08 1:24 PM, Mihael Hategan wrote:
> On Mon, 2008-07-28 at 13:13 -0500, Michael Wilde wrote:
>> I tried NCSA-HG instead (to avoid the issues of the UC two-architecture
>> site).
>> The coaster provider works for me there, using gt2:gt2:pbs, as you
>> reported previously. Same Swift script that fails on abe.
>> So it looks like something in the job specs that is launching coaster
>> for gt2:pbs is not being accepted by abe.
> That's wrong. As I mentioned before, it's the gt2:fork part that isn't
> working. You don't have that specified, but fork is always used to start
> the coaster service on the head node.
Right - I realize the error is likely coming from the fork-jobmanager
path. I meant that whatever is launching coaster for launching coaster
for gt2:pbs is failing.
Whats the closest globus-job-run or globusrun command to what the
coaster code is doing to launch the server bootstrap?
>> I also see that these log messages which I mentioned earlier do not
>> occur on the successful mercury coaster run:
>> 2008-07-28 08:22:58,853-0500 INFO ServiceManager Service task
>> Task(type=JOB_SUBMISSION, identity=urn:cog-1217251364678) terminated.
>> Removing service.
>> 2008-07-28 08:22:58,853-0500 INFO ServiceManager Service does not
>> appear to be registered with this manager
