[Swift-devel] Problems running coaster
Michael Wilde wilde at mcs.anl.gov
Mon Jul 28 13:13:56 CDT 2008
I tried NCSA-HG instead (to avoid the issues of the UC two-architecture
site).
The coaster provider works for me there, using gt2:gt2:pbs, as you
reported previously.  Same Swift script that fails on abe.
So it looks like something in the job specs that is launching coaster
for gt2:pbs is not being accepted by abe.
I also see that these log messages which I mentioned earlier do not
occur on the successful mercury coaster run:
2008-07-28 08:22:58,853-0500 INFO  ServiceManager Service task
Task(type=JOB_SUBMISSION, identity=urn:cog-1217251364678) terminated.
Removing service.
2008-07-28 08:22:58,853-0500 INFO  ServiceManager Service does not
appear to be registered with this manager
If someone can point me closer to where the swift job that launches the
bootstrap script is run from, and how, I can try to reproduce the
problem with globus-job-run or globus-run.  In the meantime I will hunt
for that.
- Mike
On 7/28/08 11:52 AM, Michael Wilde wrote:
> On 7/28/08 9:31 AM, Ben Clifford wrote:
>> On Sun, 27 Jul 2008, Michael Wilde wrote:
>>> Yes. Just *before* I tried abe with coasters, I did a simple
>>> globus-job-run to
>>> its pbs jobmanager. That worked fine.
>> try submitting with the following changes to sites.xml:
>>  1. not using coasters, instead using the gt2 provider
>>  2. not specifying tg allocation in sites.xml
> Using globus-job-run I see that only 1 account is valid.
> globus-job-run works to jobmanager-pbs, both with and without a -p
> option specifying the valid account.
> Swift using the gt2 provider also works with and without the valid
> account specified in sites.xml as a globus profile.
> Swift and the coaster provider with gt2:gt2:pbs fails both without the
> valid account (it gets the same "This node is in dedicated user mode"
> message)
> In terms of sites.xml:
> This fails (using coaster provider):
> <config>
> <pool handle="abe" >
>   <execution provider="coaster" url="grid-abe.ncsa.teragrid.org"
> jobManager="gt2:gt2:pbs" />
>   <gridftp url="gsiftp://gridftp-abe.ncsa.teragrid.org"/>
>   <workdirectory>/u/ac/wilde/swiftwork</workdirectory>
> </pool>
> </config>
> This works (using gt2 provider):
> <config>
> <pool handle="abe">
>   <jobmanager universe="vanilla"
> url="grid-abe.ncsa.teragrid.org/jobmanager-pbs" major="2"/>
> </pool>
> </config>
> I will try the same to a different TG site (starting with UC).
> - Mike
