[Swift-devel] [Bug 151] Swift gives null pointer exception
    Michael Wilde
    wilde at mcs.anl.gov
    Sun Jul 27 11:52:34 CDT 2008
On 7/27/08 11:27 AM, bugzilla-daemon at mcs.anl.gov wrote:
> http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=151
> benc at hawaga.org.uk changed:
>            What    |Removed                     |Added
>              Status|NEW                         |RESOLVED
>          Resolution|                            |WORKSFORME
> ------- Comment #3 from benc at hawaga.org.uk  2008-07-27 11:27 -------
> The attached code compiles and runs without error for me.
> Note that there appears to be no variable 'a' referred to in that source file
> at all. If you continue to have problems, please attach code and error messages
> that actually belong together.
I obviously thought I did.
Perhaps Comment #2 explains what happened?  If not I will check.
Whats the Swift logic regarding recompilation if it finds an existing
.kml file? Does that logic get fooled in some cases?
- Mike
  ------- Comment  #2 From Michael Wilde  2008-07-22 12:12  [reply] -------
It seems that if I remove the .xml and .kml files from previous
compiles, this
problem goes away, and I get instead the message that I was trying to debug
originally:
Compile error in foreach statement at line 18: Compile error in procedure
invocation at line 19: variable a is not writeable in this scope
(the line numbers here dont match the source code in the URL filed here
because
Ive changed things since then in the course of debugging).
------- Comment #3 From Ben Clifford 2008-07-27 11:27 [reply] -------
file
messages
