[Swift-devel] A naive run of Falkon+Swift on BGP login node.
Ioan Raicu iraicu at cs.uchicago.edu
Mon Jul 21 17:38:35 CDT 2008
Mihael Hategan wrote:
> On Mon, 2008-07-21 at 17:26 -0500, Zhao Zhang wrote:
>> Hi,
>> I started a test on BGP login nodes, running falkon service and swift on
>> Login6, and a worker on Login2.
>> Good news is I got the output file. Swift return successful. Bad news is
>> there are some problems I don't
>> understand.
>> The swift stdout:
>> /Line 1:    zzhang at login6.surveyor:~/swift/etc> swift -sites.file
>> ./sites.xml -tc.file ./tc.data -ip.address 172.17.3.16 first.swift
>> Line 2:    Unable to find required classes (javax.activation.DataHandler
>> and javax.mail.internet.MimeMultipart). Attachment support is disabled.
>> Line 3:    Swift svn swift-r2140 cog-r2070
>> Line 4:    RunID: 20080721-1713-zkz78kcf
>> Line 5:    Progress:
>> Line 6:    echo started
>> Line 7:    error: Notification(int timeout): socket = new
>> ServerSocket(recvPort); Address already in use
>> Line 8:    Waiting for notification for 0 ms
>> Line 9:    Received notification with 1 messages
>> Line 10:    echo completed
>> Line 11:    Final status:  Finished successfully:1/
>> 1. What is the exception in Line 2? is this ignorable or not?
> Yes. It's axis complaining about some missing stuff that is never used
> in this case.
>> 2. What is the error in Line 7? Is it printed by swift or the
>> deef-provider?
> provider-deef. Do you have another swift instance running by any chance?
>>  Is this ignorable or not?
> It isn't. It probably means that the falkon notifications won't get to
> you.
This error should just be a warning... as it tries a different port
until it finds a good one.  It should only print an error when it gives
up.  So, that is not your problem Zhao, especially as you seem to have
run OK, right?
Ioan
>> The following exception from Falkon only occurs when I specify the
>> ip.address property in swift
> What exactly did you set it to?
> Mihael
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080721/6608e8a9/attachment.html>
