[Swift-devel] Fwd: build problem with swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Jul 15 16:37:22 CDT 2008
On Tue, 2008-07-15 at 16:18 -0500, Ragib Morshed wrote:
> Can we change the dependencies such that it builds up the software
> like in eclipse?
No.
So the solution would be to pass a data structure that is available in
both. Let me think a bit.
> -ragib
> On Tue, Jul 15, 2008 at 12:27 PM, Ben Clifford <benc at hawaga.org.uk>
> wrote:
>         VDLCache is in the vdsk module.
>         The WeightedHost stuff is in karajan, which is a dependency.
>         You can't use code from module A in module B if module A is
>         dependent on
>         module B (equivalently if if module B is a prerequisite of
>         module A)
>         Here A = vdsk, B= karajan
>         There's a subclass of the weighted host scheduler that lives
>         in the vdsk
>         module and extends the functionality in swift-specific ways:
>         src//org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java
>         You might be able to add your new functionality there.
>         If its building in eclipse, that's because it enforces cog
>         module
>         dependencies differently (or not at all).
>         On Tue, 15 Jul 2008, Ragib Morshed wrote:
>         > Ben suggested forwarding this problem of mine to
>         swift-devel.
>         > ---------- Forwarded message ----------
>         > From: Ragib Morshed <ragib.morshed at gmail.com>
>         > Date: Tue, Jul 15, 2008 at 11:40 AM
>         > Subject: Fwd: build problem with swift
>         > To: benc at ci.uchicago.edu
>         > Hi Ben,
>         > I sent this email to Mihael, but he is off somewhere at a
>         conference I
>         > think, and don't know if he will get to it.
>         > I put some code in for the site-affinity thing and swift
>         compiles and runs
>         > the code fine using eclipse. Compilation/building using ant
>         says: *package
>         > org.griphyn.vdl.karajan.lib.cache does not exist. *But it is
>         there and
>         > compiles fine with eclipse.
>         > Do you have any ideas on the top of your head where the
>         problem might be?
>         > Thanks.
>         > -Ragib
>         > Date: Tue, Jul 15, 2008 at 11:25 AM
>         > Subject: build problem with swift
>         > To: Mihael Hategan <hategan at uchicago.edu>
>         > Hi,
>         > I have been trying to build swift with the new changes using
>         'ant dist', but
>         > it gives compilation error. It compiles and runs fine on
>         eclipse, but here
>         > it says it can't find the package
>         org.gridphyn.vdl.karajan.lib.cache so it
>         > cannot recognize the VDLFileCache type. Any ideas why?
>         > Here's the output from building it:
>         >     [javac] Compiling 540 source files to
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/build
>         >     [javac]
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostScoreScheduler.java:34:
>         > *package org.griphyn.vdl.karajan.lib.cache does not exist*
>         >     [javac] import
>         org.griphyn.vdl.karajan.lib.cache.VDLFileCache;
>         >     [javac]                                          ^
>         >     [javac]
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostScoreScheduler.java:230:
>         > cannot resolve symbol
>         >     [javac] symbol  : class VDLFileCache
>         >     [javac] location: class
>         > org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler
>         >     [javac]             VDLFileCache fileCache =
>         (VDLFileCache)
>         > t.getConstraint("filecache");
>         >     [javac]                 ^
>         >     [javac]
>         (VDLFileCache)
>         >     [javac]                                           ^
>         >     [javac] Note: Some input files use or override a
>         deprecated API.
>         >     [javac] Note: Recompile with -deprecation for details.
>         >     [javac] 3 errors
>         > BUILD FAILED
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/vdsk/build.xml:73: The
>         > following error occurred while executing this line:
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:442:
>         The following
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:78:
>         The following
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:51:
>         The following
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/vdsk/dependencies.xml:4:
>         > The following error occurred while executing this line:
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:162:
>         The following
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:167:
>         The following
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/build.xml:59:
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:463:
>         The following
>         > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:227:
>         Compile failed;
>         > see the compiler error output for details.
>         > Total time: 30 seconds
>         > -ragib
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
