[Swift-devel] Fwd: build problem with swift
Ragib Morshed ragib.morshed at gmail.com
Tue Jul 15 16:18:20 CDT 2008
Can we change the dependencies such that it builds up the software like in
eclipse?
-ragib
On Tue, Jul 15, 2008 at 12:27 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> VDLCache is in the vdsk module.
> The WeightedHost stuff is in karajan, which is a dependency.
> You can't use code from module A in module B if module A is dependent on
> module B (equivalently if if module B is a prerequisite of module A)
> Here A = vdsk, B= karajan
> There's a subclass of the weighted host scheduler that lives in the vdsk
> module and extends the functionality in swift-specific ways:
> src//org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java
> You might be able to add your new functionality there.
> If its building in eclipse, that's because it enforces cog module
> dependencies differently (or not at all).
> On Tue, 15 Jul 2008, Ragib Morshed wrote:
> > Ben suggested forwarding this problem of mine to swift-devel.
> > ---------- Forwarded message ----------
> > From: Ragib Morshed <ragib.morshed at gmail.com>
> > Date: Tue, Jul 15, 2008 at 11:40 AM
> > Subject: Fwd: build problem with swift
> > To: benc at ci.uchicago.edu
> > Hi Ben,
> > I sent this email to Mihael, but he is off somewhere at a conference I
> > think, and don't know if he will get to it.
> > I put some code in for the site-affinity thing and swift compiles and
> runs
> > the code fine using eclipse. Compilation/building using ant says:
> *package
> > org.griphyn.vdl.karajan.lib.cache does not exist. *But it is there and
> > compiles fine with eclipse.
> > Do you have any ideas on the top of your head where the problem might be?
> > Thanks.
> > -Ragib
> > Date: Tue, Jul 15, 2008 at 11:25 AM
> > Subject: build problem with swift
> > To: Mihael Hategan <hategan at uchicago.edu>
> > Hi,
> > I have been trying to build swift with the new changes using 'ant dist',
> but
> > it gives compilation error. It compiles and runs fine on eclipse, but
> here
> > it says it can't find the package org.gridphyn.vdl.karajan.lib.cache so
> it
> > cannot recognize the VDLFileCache type. Any ideas why?
> > Here's the output from building it:
> >     [javac] Compiling 540 source files to
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/build
> >     [javac]
> /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostScoreScheduler.java:34:
> > *package org.griphyn.vdl.karajan.lib.cache does not exist*
> >     [javac] import org.griphyn.vdl.karajan.lib.cache.VDLFileCache;
> >     [javac]                                          ^
> >     [javac]
> /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/src/org/globus/cog/karajan/scheduler/WeightedHostScoreScheduler.java:230:
> > cannot resolve symbol
> >     [javac] symbol  : class VDLFileCache
> >     [javac] location: class
> > org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler
> >     [javac]             VDLFileCache fileCache = (VDLFileCache)
> > t.getConstraint("filecache");
> >     [javac]                 ^
> >     [javac]
> >     [javac]                                           ^
> >     [javac] Note: Some input files use or override a deprecated API.
> >     [javac] Note: Recompile with -deprecation for details.
> >     [javac] 3 errors
> > BUILD FAILED
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/vdsk/build.xml:73:
> The
> > following error occurred while executing this line:
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:442: The following
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:78: The following
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:51: The following
> /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/vdsk/dependencies.xml:4:
> > The following error occurred while executing this line:
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:162: The following
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:167: The following
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/modules/karajan/build.xml:59:
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:463: The following
> > /autonfs/home/rmorshed/Desktop/swiftNew/cog/mbuild.xml:227: Compile
> failed;
> > see the compiler error output for details.
> > Total time: 30 seconds
> > -ragib
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080715/66a83d09/attachment.html>
