[Swift-devel] [VOTE] 0.6 release plan
    Ben Clifford
    benc at hawaga.org.uk
    Mon Jul  7 04:39:07 CDT 2008
This is a new attempt to make a 0.6 release. The release plan below is
roughly the same as my last abortive attempt at making a release, except
that I no longer propose using dev.globus release procedure.
I will be the release manager for Swift 0.6.
I'm going to make a release candidate for 0.6 sometime
within the next three days, and hope to release that as 0.6 proper next
weekend (maybe 6 days from now).
I'm hoping to have a single release candidate, with minor bugs being noted
and fixed in 0.7 rather than causing a new release candidate.
I'm planning on announcing coasters and replication as experimental
features which we encourage interested parties to experiment with and
report their experiences.
There will be no repository freeze for this release.
This release will use the traditional Swift release process, not the
dev.globus release process. A release will be made when the release
manager (me) sees fit, rather than based on voting.
This release plan is subject to 'Lazy Majority' approval, which means that
this plan is automatically approved until/unless someone votes -1. So
pretty much you do not need to vote +1 until/unless someone votes -1. If
you wish to vote -1, it appears that you should vote -1 specifically for
the issues that you disagree with rather than the plan as a whole.
