[Swift-devel] multiple worker.sh in the same job
Ben Clifford benc at hawaga.org.uk
Tue Jul 1 16:11:27 CDT 2008
Here is one problem with Swift + MPI, with workaround, that Andriy Fedorov
<fedorov at cs.wm.edu> and I have uncovered. I'm interested in anyone's
commentary.
If you use GRAM with jobtype=mpi, then your job is run through mpirun, and
thus executes on each node in the job rather than once.
In the case of Swift submitting this way, 'your job' actually means the
Swift server side code, wrapper.sh, not 'your (the user's) job'.
This means there are multiple wrapper.sh jobs running, all trying to use
the same working directory, input files and output files.
Andriy tried making only one of the nodes create output files (eg the rank
0 node), and that appears to work in his case, though I think the
following is happening:
  * each worker will link the same input files into the same working
    directory. if this was a copy, this would be a potentially damaging
    race condition. as its a link, I think there is a still a race
    condition there that would cause some of the workers to fail (so
    perhaps in the presence of any input files at all this won't work - I
    think Andriy's test case does not have any input files).
  * I think that all except the rank-0 wrapper script indicates failure
    (because of missing output files); and the rank-0 wrapper script
    indicates success. Swift submit-side checks for success flag before
    failure flag, so regards the job as successful. I think this only
    works if at least one job succeeds, which pretty much means one job
    must generate all the output files, rather than different jobs
    generating different output files.
I haven't really tested the above out in great depth, but I think that is
what is happening
>From a technical perspective, I think the way to address this is to swap
the mpirun and wrapper.sh, so that one wrapper.sh runs, and inside that it
runs mpirun which then spawns only the application executables.
There you lose the abstraction from GRAM of being able to specify
jobtype=mpi; instead you have to know how to do this yourself, and run the
job as a normal, not mpi, job from GRAM's perspective.
However, in the case of non-GRAM execution mechanisms, then that
abstraction is not in place anyway.
