[Swift-devel] Support request: Swift jobs flooding uc-teragrid?
    Stuart Martin
    smartin at mcs.anl.gov
    Wed Jan 30 11:23:55 CST 2008
On Jan 30, 2008, at Jan 30, 11:21 AM, Stuart Martin wrote:
> All,
> I wanted to chime in with a number of things being discussed here.
> There is a GRAM RFT Core reliability group focused on ensuring the
> GRAM service stays up and functional in spit of an onslaught from a
> client.  http://confluence.globus.org/display/CDIGS/GRAM-RFT-Core+Reliability+Tiger+Team
> The ultimate goal here is that a client may get a timeout and that
> would be the signal to backoff some.
> OSG - VO testing: We worked with Terrence (CMS) recently and here
> are his test results.
> 	http://hepuser.ucsd.edu/twiki/bin/view/UCSDTier2/WSGramTests
> GRAM2 handled this 2000 jobs x 2 condor-g clients to the same GRAM
> service better than GRAM4.  But again, this is with the condor-g
> tricks.  Without the tricks, GRAM2 will handle the load better.
Without the tricks, *GRAM4* will handle the load better.
> OSG VTB testing: These were using globusrun-ws and also condor-g.
> 	https://twiki.grid.iu.edu/twiki/bin/view/Integration/WSGramValidation
> clients in these tests got a variety of errors depending on the jobs
> run: timeouts, GridFTP authentication errors, client-side OOM, ...
> GRAM4 functions pretty well, but it was not able to handle
> Terrence's scenario.  But it handled 1000 jobs x 1 condor-g client
> just fine.
> It would be very interesting to see how swift does with GRAM4.  This
> would make for a nice comparison to condor-g.
> As far as having functioning GRAM4 services on TG, things have
> improved.  LEAD is using GRAM4 exclusively and we've been working
> with them to make sure the GRAM4 services are up and functioning.
> INCA has been updated to more effectively test and monitor GRAM4 and
> GridFTP services that LEAD is targeting.  This could be extended for
> any hosts that swift would like to test against.  Here are some
> interesting charts from INCA - http://cuzco.sdsc.edu:8085/cgi-bin/lead.cgi
> -Stu
> On Jan 30, 2008, at Jan 30, 10:00 AM, Ti Leggett wrote:
>> On Jan 30, 2008, at 01/30/08 09:48 AM, Ben Clifford wrote:
>> [snip]
>>> No. The default behaviour when working with a user who is "just
>>> trying to
>>> get their stuff to run" is "screw this, use GRAM2 because it works".
>>> Its a self-reinforcing feedback loop, that will be broken at the
>>> point
>>> that it becomes easier for people to stick with GRAM4 than default
>>> back to
>>> GRAM2. I guess we need to keep trying every now and then and hope
>>> that one
>>> time it sticks ;-)
>> Well this works to a point, but if falling back to a technology
>> that is known to not be scalable for your sizes results in killing
>> a machine, I, as a site admin, will eventually either a) deny you
>> service b) shut down the poorly performing service or c) all of the
>> above. So it's in your best interest to find and use those
>> technologies that are best suited to the task at hand so the users
>> of your software don't get nailed by (a).
>> In this case it seems to me that using WS-GRAM, extending WS-GRAM
>> and/or MDS to report site statistics, and/or modifying WS-GRAM to
>> throttle itself (think of how apache reports "Server busy. Try
>> again later") is the best path forward. For the short term, it
>> seems that the Swift developers should manually find those limits
>> for sites that the users use regularly for them to use, *and*
>> educate their users on how to identify that they could be adversely
>> affecting a resource and throttle themselves till the ideal,
>> automated method is a usable reality.
