[Swift-devel] Support request: Swift jobs flooding uc-teragrid?
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Wed Jan 30 08:46:40 CST 2008
If MDS will give you this kind of info, and its already available to
you, then why not use it to determine the load on the remote machine?
Ben Clifford wrote:
> On Wed, 30 Jan 2008, Ioan Raicu wrote:
>> Here is something that might help Swift determine when the GRAM host is under
>> heavy load, prior to things starting to fail.
>> Could a simple service be made to run in the same container as the GRAM4
>> service that would expose certain low level information, such as CPU
> That's reinventing MDS!
> We used to have a great set of cross-platform submit-host information
> scripts but for whatever reason decided to abandon them (though they're
> still used in gLite, I think).
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://www.ci.uchicago.edu/wiki/bin/view/VDS/DslCS
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080130/c9e4cbc1/attachment.html>
