[Swift-devel] Re: Swift jobs on UC/ANL TG
    joseph insley
    insley at mcs.anl.gov
    Tue Jan 29 09:20:53 CST 2008
Yes, the local project id is typically created by swapping UC for TG
in the TG project id.
I believe these jobs are in fact PBS jobs submitted to the scheduler
through gram.  However, pre-ws gram forks off a jobmanager process
for each job that is submitted, to keep track of state, etc.  This is
a known limitation of pre-ws gram.
joe.
On Jan 29, 2008, at 9:01 AM, Mike Kubal wrote:
> Yes, I have a TG project. I should have updated my
> swift sites file after initial testing.
> Is it common for the TG project id to be the same as
> the local with just the 'TG-' and 'UC'- prefix
> switched?
> --- Ti Leggett <leggett at mcs.anl.gov> wrote:
>> Also, it looks like you're using a local project and
>> not a TG project.
>> We are not able to report this usage to NSF because
>> it counts against
>> our discretionary usage. Do you have a TG project?
>> If not can you
>> request a DACC allocation to use?
>> On Jan 28, 2008, at 01/28/08 07:13 PM, Mike Kubal
>> wrote:
>>> Yes, I'm submitting molecular dynamics simulations
>>> using Swift.
>>> Is there a default wall-time limit for jobs on
>> tg-uc?
>>> --- joseph insley <insley at mcs.anl.gov> wrote:
>>>> Actually, these numbers are now escalating...
>>>> top - 17:18:54 up  2:29,  1 user,  load average:
>>>> 149.02, 123.63, 91.94
>>>> Tasks: 469 total,   4 running, 465 sleeping,   0
>>>> stopped,   0 zombie
>>>> insley at tg-grid1:~> ps -ef | grep kubal | wc -l
>>>>     479
>>>> insley at tg-viz-login1:~> time globusrun -a -r
>>>> tg-grid.uc.teragrid.org
>>>> GRAM Authentication test successful
>>>> real    0m26.134s
>>>> user    0m0.090s
>>>> sys     0m0.010s
>>>> On Jan 28, 2008, at 5:15 PM, joseph insley wrote:
>>>>> Earlier today tg-grid.uc.teragrid.org (the
>> UC/ANL
>>>> TG GRAM host)
>>>>> became unresponsive and had to be rebooted.  I
>> am
>>>> now seeing slow
>>>>> response times from the Gatekeeper there again.
>>>> Authenticating to
>>>>> the gatekeeper should only take a second or two,
>>>> but it is
>>>>> periodically taking up to 16 seconds:
>>>>> real    0m16.096s
>>>>> user    0m0.060s
>>>>> sys     0m0.020s
>>>>> looking at the load on tg-grid, it is rather
>> high:
>>>>> top - 16:55:26 up  2:06,  1 user,  load average:
>>>> 89.59, 78.69, 62.92
>>>>> Tasks: 398 total,  20 running, 378 sleeping,   0
>>>> stopped,   0 zombie
>>>>> And there appear to be a large number of
>> processes
>>>> owned by kubal:
>>>>>    380
>>>>> I assume that Mike is using swift to do the job
>>>> submission.  Is
>>>>> there some throttling of the rate at which jobs
>>>> are submitted to
>>>>> the gatekeeper that could be done that would
>>>> lighten this load
>>>>> some?  (Or has that already been done since
>>>> earlier today?)  The
>>>>> current response times are not unacceptable, but
>>>> I'm hoping to
>>>>> avoid having the machine grind to a halt as it
>> did
>>>> earlier today.
>>>>> Thanks,
>>>>> joe.
>>>>> joseph a.
>>>>> insley
>>>>> mathematics & computer science division
>>>> (630) 252-5649
>>>>> argonne national laboratory
>>>>       (630)
>>>>> 252-5986 (fax)
>>>> joseph a. insley
>> (630)
>>>> 252-5649
>>>>     (630)
>>>> 252-5986 (fax)
> ______________________________________________________________________
> ______________
>>> Be a better friend, newshound, and
>>> know-it-all with Yahoo! Mobile.  Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> ______________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
joseph a. insley
mathematics & computer science division       (630) 252-5649
argonne national laboratory                               (630)
252-5986 (fax)
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080129/9af7a87c/attachment.html>
