[Swift-devel] Re: Criteria for rollout
Ben Clifford benc at hawaga.org.uk
Thu Jan 10 18:04:07 CST 2008
On Thu, 10 Jan 2008, Mihael Hategan wrote:
> Another good point. @filenames. But then looking at the code for passing
> an array, it doesn't seem like it keeps any particular order either:
I didn't even know passing an array outside of @filenames worked...
> if (handle.getType().isArray()) {
>   Map value = handle.getArrayValue();
>   if (handle.isClosed()) {
>     return new PairIterator(value);
> public PairIterator(Map map) {
>   this.it = map.entrySet().iterator();
> However, @filenames hurts. The other one not as much.
yeah.
I think the correct behaviour should be to output in the order of the
array indices (for both plain array passing and for @filenames).
I don't think anything else maps over an array apart from @filenames.
