[Swift-devel] Re: latest attempt with GRAM4
joseph insley
insley at mcs.anl.gov
Tue Feb 12 16:48:05 CST 2008
If a project id is specified explicitly in the job description, that
takes precedence over the default project. Could it be that the
correct one was previously specified in the job request?
joe.
On Feb 12, 2008, at 4:23 PM, Mihael Hategan wrote:
> Would it be worth trying to find out why it worked with pre-WS GRAM?
> Mihael
> On Tue, 2008-02-12 at 14:20 -0800, Mike Kubal wrote:
>> Thanks Joe. This solved the account id problem.
>> --- joseph insley <insley at mcs.anl.gov> wrote:
>>> Mike K,
>>> looks like you have the wrong value in your
>>> .tg_default_project file:
>>> insley at tg-viz-login1:~> more
>>> ~kubal/.tg_default_project
>>> TG-MCA01S018
>>> you should be using: TG-MCB010025N
>>> insley at tg-viz-login1:~> tgusage -i -u kubal
>>> [snip]
>>> Account: TG-MCA01S018
>>> Title: Computational Studies of Complex Processes in
>>> Biological
>>> Macromolecular Systems
>>> Resource: teragrid
>>> Local project name on dtf.anl.teragrid is
>>> TG-MCB010025N
>>> Allocation Period: 2007-08-03 to 2008-03-31
>>> Name (Last First) or Account Total
>>> Remaining Usage
>>> Kubal Michael 101880 SU
>>> 99358 SU 296 SU
>>> TG-MCA01S018 101880 SU
>>> 99358 SU 2522 SU
>>> On Feb 12, 2008, at 2:37 PM, Mihael Hategan wrote:
>>>> You should probably remove the line completely.
>>>> Did you chose a default project on the login node
>>> with tgprojects?
>>>> On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal
>>> wrote:
>>>>> I tried running with the account id removed from
>>> the
>>>>> sites.file as in the following line:
>>>>> <profile namespace="globus" key=""></profile>
>>>>> but received the same error.
>>>>> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>>>>> Is this the same for pre-WS GRAM?
>>>>>> On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin
>>>>>> wrote:
>>>>>>> that's right, qsub is used for PBS (and some
>>>>>> others too)
>>>>>>> bsub is LSF
>>>>>>> condor_q for condor
>>>>>>> -Stu
>>>>>>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
>>>>>> Hategan wrote:
>>>>>>>> On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal
>>>>>> wrote:
>>>>>>>>> I'll give it a try.
>>>>>>>>> When using GRAM4, is qsub the method used to
>>>>>>>>> ultimately put the job in the queue?
>>>>>>>> Looks like it. I also believe it's the case
>>> with
>>>>>> pre-ws gram. Stu
>>>>>>>> may be
>>>>>>>> able to clarify.
>>>>>>>>> MikeK
>>> wrote:
>>>>>>>>>> While this doesn't solve the underlying
>>>>>> problem, it
>>>>>>>>>> may help you get
>>>>>>>>>> this to work: log into tg-login1.uc..., set
>>>>>> this
>>>>>>>>>> project as default,
>>>>>>>>>> then remove the project spec from the sites
>>>>>> file and
>>>>>>>>>> try again.
>>>>>>>>>> Mihael
>>>>>>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike
>>> Kubal
>>>>>> wrote:
>>>>>>>>>>> Yes, I believe you are right. The kickstart
>>>>>>>>>> message
>>>>>>>>>>> may be only a warning. After digging a
>>> little
>>>>>>>>>> deeper
>>>>>>>>>>> it appears the job is failing due to a
>>>>>>>>>> project/account
>>>>>>>>>>> id problem. I get the following error:
>>>>>>>>>>> Caused by:
>>>>>>>>>>> The executable could not be
>>> started.,
>>>>>>>>>> qsub:
>>>>>>>>>>> Invalid Account MSG=invalid account
>>>>>>>>>>> I am specifying the same TG-account in my
>>>>>>>>>> site-file
>>>>>>>>>>> for the gram4 run that fails, as in the
>>>>>> site-file
>>>>>>>>>> for
>>>>>>>>>>> the pre-ws job that suceeds. This is the
>>> same
>>>>>>>>>> project,
>>>>>>>>>>> TG-MCA01S018, that is set in my
>>>>>>>>>> .tg_default_project
>>>>>>>>>>> file in ~kubal/ on the UC teragrid.
>>>>>>>>>>> --- Ben Clifford <benc at hawaga.org.uk>
>>> wrote:
>>>>>>>>>>>> yeah, run that same without kickstart. the
>>>>>> error
>>>>>>>>>>>> reported is that
>>>>>>>>>>>> kickstart didn't work right - but there's
>>>>>>>>>> perhaps
>>>>>>>>>>>> some underlying error.
>> _____________________________________________________________________
>>>>> _______________
>>>>>>>>>>> Never miss a thing. Make Yahoo your home
>>>>>> page.
>>>>>>>>>>> http://www.yahoo.com/r/hs
>>>>> _______________
>>>>>>>>> Be a better friend, newshound, and
>>>>>>>>> know-it-all with Yahoo! Mobile. Try it now.
>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> === message truncated ===
>> _______________
>> Looking for last minute shopping deals?
>> Find them fast with Yahoo! Search. http://tools.search.yahoo.com/
>> newsearch/category.php?category=shopping
