[Swift-devel] cog r1871
Mihael Hategan hategan at mcs.anl.gov
Mon Feb 11 10:59:52 CST 2008
On Mon, 2008-02-11 at 10:01 -0600, Mihael Hategan wrote:
> On Mon, 2008-02-11 at 14:28 +0000, Ben Clifford wrote:
> > On my laptop, I'm getting the below error message with latest cog and my
> > development swift.
> > cog r1864 doesn't give this problem. cog r1871 does (there's nothing in
> > between those two commits in the piece of the cog svn that swift uses)
> I know what causes the problem.
Actually I don't. I only have a suspicion. Can you send me the logs?
>  It's r1871, as you say.
> > echo failed
> > Execution failed:
> >         Exception in echo:
> > Arguments: [hello]
> > Host: tp-fork-gram2
> > Directory: 001-echo-20080211-1419-kvenil6g/jobs/m/echo-mn9fr9oi
> > stderr.txt:.
> > stdout.txt:.
> > Caused by:
> >         Exception in getFile
> > Caused by:
> >         Server refused performing the request. Custom message:  (error
> > code 1) [Nested exception message:  Custom message: Unexpected reply: 451
> > refusing to store with active mode
> > org.globus.ftp.exception.DataChannelException: setPassive() must match
> > store() and setActive() - retrieve()  (error code 2)
> >         at
> > org.globus.ftp.extended.GridFTPServerFacade.store(GridFTPServerFacade.java:317)
> >         at org.globus.ftp.FTPClient.get(FTPClient.java:1236)
> >         at
> > org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.getFile(FileResourceImpl.java:359)
> >         at
> > org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doSource(DelegatedFileTransferHandler.java:275)
> >         at
> > org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doSource(CachingDelegatedFileTransferHandler.java:60)
> >         at
> > org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:490)
> >         at java.lang.Thread.run(Thread.java:613)
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
