[Swift-devel] ws-gram tests
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Feb  8 16:37:18 CST 2008
On Fri, 2008-02-08 at 16:32 -0600, feller at mcs.anl.gov wrote:
> I can't see any stability issues here. The only thing i changed
> is using
> EndpointReferenceType jobEPR = (EndpointReferenceType)
>     ObjectSerializer.clone(response.getManagedJobEndpoint());
> instead of
> EndpointReferenceType jobEPR = response.getManagedJobEndpoint();
> at 2 or 3 locations in the code.
> Rachana uses cloning in core too. So it's supposed to be
> a stable thing.
> A question though: Do you see a speedup in submission?
I wasn't looking for that. Anything I should be aware of?
> Martin
> > Yep. Looks much better. How stable is this otherwise?
> > On Fri, 2008-02-08 at 15:02 -0600, Mihael Hategan wrote:
> >> On a first look it indeed looks like the gc is more successful at
> >> cleaning stuff up.
> >> On Fri, 2008-02-08 at 13:21 -0600, feller at mcs.anl.gov wrote:
> >> > Try the attached 4.0 compliant jar in your tests by dropping
> >> > it in your 4.0.x $GLOBUS_LOCATION/lib.
> >> > My tests showed about 2MB memory increase per 100 GramJob
> >> > objects which sounds to me like a reasonable number (about 20k
> >> > per GramJob object ignoring the notification consumer manager
> >> > in one job - if my calculations are right)
> >> > Martin
> >> > > On Fri, 2008-02-08 at 11:19 -0600, feller at mcs.anl.gov wrote:
> >> > >> Mihael,
> >> > >> i think i found the memory hole in GramJob.
> >> > >> 100 jobs in a test of mine consumed about 23MB (constantly
> >> > >> growing) before the fix and 8MB (very slowly growing) after
> >> > >> the fix. The big part of that (7MB) is used right from the
> >> > >> first job which may be the NotificationConsumerManager.
> >> > >> Will commit that change soon to 4.0 branch and you may try
> >> > >> it then.
> >> > >> Are you using 4.0.x in your tests?
> >> > > Yes. If there are no API changes, you can send me the jar file. I
> >> don't
> >> > > have enough knowledge to selectively build WS-GRAM, nor enough disk
> >> > > space to build the whole GT.
> >> > >> Martin
> >> > >> >>> > These are both hacks. I'm not sure I want to go there. 300K
> >> per
> >> > >> job
> >> > >> >>> is
> >> > >> >>> a
> >> > >> >>> > bit too much considering that swift (which has to consider
> >> many
> >> > >> more
> >> > >> >>> > things) has less than 10K overhead per job.
> >> > >> >>> For my better understanding:
> >> > >> >>> Do you start up your own notification consumer manager that
> >> listens
> >> > >> for
> >> > >> >>> notifications of all jobs or do you let each GramJob instance
> >> listen
> >> > >> >>> for
> >> > >> >>> notifications itself?
> >> > >> >>> In case you listen for notifications yourself: do you store
> >> > >> >>> GramJob objects or just EPR's of jobs and create GramJob
> >> objects if
> >> > >> >>> needed?
> >> > >> >> Excellent points. I let each GramJob instance listen for
> >> > >> notifications
> >> > >> >> itself. What I observed is that it uses only one container for
> >> that.
> >> > >> > Shoot! i didn't know that and thought there would be a container
> >> per
> >> > >> > GramJob in that case. That's the core mysteries with
> >> notifications.
> >> > >> > Anyway: I did a quick check some days ago and found that GramJob
> >> is
> >> > >> > surprisingly greedy regarding memory as you said. I'll have to
> >> further
> >> > >> > check what it is, but will probably not do that before 4.2 is
> >> out.
> >> > >> >> Due to the above, a reference to the GramJob is kept anyway,
> >> > >> regardless
> >> > >> >> of whether that reference is in client code or the local
> >> container.
> >> > >> >> I'll try to profile a run and see if I can spot where the
> >> problems
> >> > >> are.
> >> > >> >>> Martin
> >> > >> >>> >> The core team will be looking at improving notifications
> >> once
> >> > >> their
> >> > >> >>> >> other 4.2 deliverables are done.
> >> > >> >>> >> -Stu
> >> > >> >>> >> Begin forwarded message:
> >> > >> >>> >> > From: feller at mcs.anl.gov
> >> > >> >>> >> > Date: February 1, 2008 9:41:05 AM CST
> >> > >> >>> >> > To: "Jaime Frey" <jfrey at cs.wisc.edu>
> >> > >> >>> >> > Cc: "Stuart Martin" <smartin at mcs.anl.gov>, "Terrence
> >> Martin"
> >> > >> >>> >> <tmartin at physics.ucsd.edu
> >> > >> >>> >> > >, "Martin Feller" <feller at mcs.anl.gov>, "charles bacon"
> >> > >> >>> >> <bacon at mcs.anl.gov
> >> > >> >>> >> > >, "Suchandra Thapa" <sthapa at ci.uchicago.edu>, "Rob
> >> Gardner"
> >> > >> >>> >> <rwg at hep.uchicago.edu
> >> > >> >>> >> > >, "Jeff Porter" <rjporter at lbl.gov>, "Alain Roy"
> >> > >> >>> <roy at cs.wisc.edu>,
> >> > >> >>> >> > "Todd Tannenbaum" <tannenba at cs.wisc.edu>, "Miron Livny"
> >> > >> >>> >> <miron at cs.wisc.edu
> >> > >> >>> >> > Subject: Re: Condor-G WS GRAM memory usage
> >> > >> >>> >> >> On Jan 31, 2008, at 6:26 PM, Jaime Frey wrote:
> >> > >> >>> >> >>> On Jan 30, 2008, at 12:25 PM, Stuart Martin wrote:
> >> > >> >>> >> >>>> On Jan 30, 2008, at Jan 30, 11:46 AM, Jaime Frey wrote:
> >> > >> >>> >> >>>>> Terrence Martin's scalability testing of Condor-G with
> >> WS
> >> > >> GRAM
> >> > >> >>> >> >>>>> raised some concerns about memory usage on the client
> >> side.
> >> > >> I
> >> > >> >>> did
> >> > >> >>> >> >>>>> some profiling of Condor-G's WS GRAM GAHP server,
> >> which
> >> > >> >>> appeared
> >> > >> >>> >> >>>>> to be the primary memory consumer. The GAHP server is
> >> a
> >> > >> >>> wrapper
> >> > >> >>> >> >>>>> around the java client libraries for WS GRAM.
> >> > >> >>> >> >>>>> In my tests, I submitted variable numbers of jobs up
> >> to 30
> >> > >> at
> >> > >> >>> a
> >> > >> >>> >> >>>>> time. The jobs were 2-minute sleep jobs with minimal
> >> data
> >> > >> >>> >> >>>>> transfer. All of the jobs overlapped in submission and
> >> > >> >>> execution.
> >> > >> >>> >> >>>>> Here is what I've discovered so far.
> >> > >> >>> >> >>>>> Aside from the heap available to the java code, the
> >> jvm
> >> > >> used
> >> > >> >>> 117
> >> > >> >>> >> >>>>> megs of non-shared memory and 74 megs of shared
> >> memory.
> >> > >> >>> Condor-G
> >> > >> >>> >> >>>>> creates one GAHP server for each (local uid, X509 DN)
> >> pair.
> >> > >> >>> >> >>>>> The maximum jvm heap usage (as reported by the garbage
> >> > >> >>> collector)
> >> > >> >>> >> >>>>> was about 9 megs plus 0.9 megs per job. When the GAHP
> >> was
> >> > >> >>> >> >>>>> quiescent (jobs executing, Condor-G waiting for them
> >> to
> >> > >> >>> complete),
> >> > >> >>> >> >>>>> heap usage was about 5 megs plus 0.6 megs per job.
> >> > >> >>> >> >>>>> The only long-term memory per job that I know of in
> >> the
> >> > >> GAHP
> >> > >> >>> is
> >> > >> >>> >> >>>>> for the notification sink for job status callbacks.
> >> 600kb
> >> > >> >>> seems
> >> > >> >>> a
> >> > >> >>> >> >>>>> little high for that. Stu, could someone on Globus
> >> help us
> >> > >> >>> >> >>>>> determine if we're using the notification sinks
> >> > >> inefficiently?
> >> > >> >>> >> >>>> Martin just looked and for the most part, there is
> >> nothing
> >> > >> >>> wrong
> >> > >> >>> >> >>>> with how condor-g manages the callback sink.
> >> > >> >>> >> >>>> However, one improvement that would reduce the memory
> >> used
> >> > >> per
> >> > >> >>> job
> >> > >> >>> >> >>>> would be to not have a notification consumer per job.
> >> > >> Instead
> >> > >> >>> use
> >> > >> >>> >> >>>> one for all jobs.
> >> > >> >>> >> >>>> Also, Martin recently did some analysis on condor-g
> >> stress
> >> > >> >>> tests
> >> > >> >>> >> >>>> and found that notifications are building up on the in
> >> the
> >> > >> >>> GRAM4
> >> > >> >>> >> >>>> service container and that is causing delays which seem
> >> to
> >> > >> be
> >> > >> >>> >> >>>> causing multiple problems.  We're looking at this in a
> >> > >> separate
> >> > >> >>> >> >>>> effort with the GT Core team.  But, after this was
> >> clear,
> >> > >> >>> Martin
> >> > >> >>> >> >>>> re-
> >> > >> >>> >> >>>> ran the condor-g test and relied on polling between
> >> condor-g
> >> > >> >>> and
> >> > >> >>> >> >>>> the GRAM4 service instead of notifications.  Jaime,
> >> could
> >> > >> you
> >> > >> >>> >> >>>> repeat the no-notification test and see the difference
> >> in
> >> > >> >>> memory?
> >> > >> >>> >> >>>> The changes would be to increase the polling frequency
> >> in
> >> > >> >>> condor-g
> >> > >> >>> >> >>>> and comment out the subscribe for notification.  You
> >> could
> >> > >> also
> >> > >> >>> >> >>>> comment out the notification listener call(s) too.
> >> > >> >>> >> >>> I did two new sets of tests today. The first used more
> >> > >> efficient
> >> > >> >>> >> >>> callback code in the GAHP (one notification consumer
> >> rather
> >> > >> than
> >> > >> >>> one
> >> > >> >>> >> >>> per job). The second disabled notifications and relied
> >> on
> >> > >> >>> polling
> >> > >> >>> >> >>> for job status changes.
> >> > >> >>> >> >>> The more efficient callback code did not produce a
> >> noticeable
> >> > >> >>> >> >>> reduction in memory usage.
> >> > >> >>> >> >>> Disabling notifications did reduce memory usage. The
> >> maximum
> >> > >> jvm
> >> > >> >>> >> >>> heap usage was roughly 8 megs plus 0.5 megs per job. The
> >> > >> minimum
> >> > >> >>> >> >>> heap usage after job submission and before job
> >> completion was
> >> > >> >>> about
> >> > >> >>> >> >>> 4 megs + 0.1 megs per job.
> >> > >> >>> >> >> I ran one more test with the improved callback code. This
> >> > >> time, I
> >> > >> >>> >> >> stopped storing the notification producer EPRs associated
> >> with
> >> > >> >>> the
> >> > >> >>> >> >> GRAM job resources. Memory usage went down markedly.
> >> > >> >>> >> >> I was told the client had to explicitly destroy these
> >> > >> serve-side
> >> > >> >>> >> >> notification producer resources when it destroys the job,
> >> > >> >>> otherwise
> >> > >> >>> >> >> they hang around bogging down the server. Is this still
> >> the
> >> > >> case?
> >> > >> >>> The
> >> > >> >>> >> >> server can't destroy notification producers when their
> >> sources
> >> > >> of
> >> > >> >>> >> >> information are destroyed?
> >> > >> >>> >> > This reminds me of the odd fact that i had to suddenly
> >> grant
> >> > >> much
> >> > >> >>> more
> >> > >> >>> >> > memory to Condor-g as soon as condor-g started storing
> >> EPRs of
> >> > >> >>> >> > subscription resources to be able to destroy them
> >> eventually.
> >> > >> >>> >> > Those EPR's are maybe not so tiny as they look like.
> >> > >> >>> >> > For 4.0: yes, currently you'll have to store and
> >> eventually
> >> > >> >>> destroy
> >> > >> >>> >> > subscription resources manually to avoid heaping up
> >> persistence
> >> > >> >>> data
> >> > >> >>> >> > on the server-side.
> >> > >> >>> >> > For 4.2: no, you won't have to store them. A job resource
> >> will
> >> > >> >>> >> > destroy all subscription resources when it's destroyed.
> >> > >> >>> >> > Overall i suggest to concentrate on 4.2 gram since the
> >> > >> "container
> >> > >> >>> >> > hangs in job destruction" problem won't exist anymore.
> >> > >> >>> >> > Sorry, Jaime, i still can't provide you with 100% reliable
> >> 4.2
> >> > >> >>> changes
> >> > >> >>> >> > in Gram in 4.2. I'll do so as soon as i can. I wonder if
> >> it
> >> > >> makes
> >> > >> >>> >> > sense
> >> > >> >>> >> > for us to do the 4.2-related changes in Gahp and hand it
> >> to you
> >> > >> >>> for
> >> > >> >>> >> > fine-tuning then?
> >> > >> >>> >> > Martin
> >> > >> >>> >> On Feb 8, 2008, at Feb 8, 9:19 AM, Ian Foster wrote:
> >> > >> >>> >> > Mihael:
> >> > >> >>> >> > That's great, thanks!
> >> > >> >>> >> > Ian.
> >> > >> >>> >> >> I did a 1024 job run today with ws-gram.
> >> > >> >>> >> >> I painted the results here:
> >> > >> >>> >> >> http://www-unix.mcs.anl.gov/~hategan/s/g.html
> >> > >> >>> >> >> Seems like client memory per job is about 370k. Which is
> >> quite
> >> > >> a
> >> > >> >>> lot.
> >> > >> >>> >> >> What kinda worries me is that it doesn't seem to go down
> >> after
> >> > >> >>> the
> >> > >> >>> >> >> jobs
> >> > >> >>> >> >> are done, so maybe there's a memory leak, or maybe the
> >> garbage
> >> > >> >>> >> >> collector
> >> > >> >>> >> >> doesn't do any major collections. I'll need to profile
> >> this to
> >> > >> >>> see
> >> > >> >>> >> >> exactly what we're talking about.
> >> > >> >>> >> >> The container memory is figured by looking at the process
> >> in
> >> > >> >>> /proc.
> >> > >> >>> >> >> It's
> >> > >> >>> >> >> total memory including shared libraries and things. But
> >> > >> libraries
> >> > >> >>> >> >> take a
> >> > >> >>> >> >> fixed amount of space, so a fuzzy correlation can
> >> probably be
> >> > >> >>> made.
> >> > >> >>> >> >> It
> >> > >> >>> >> >> looks quite similar to the amount of memory eaten on the
> >> > >> client
> >> > >> >>> side
> >> > >> >>> >> >> (per job).
> >> > >> >>> >> >> CPU-load-wise, WS-GRAM behaves. There is some work during
> >> the
> >> > >> >>> time
> >> > >> >>> >> >> the
> >> > >> >>> >> >> jobs are submitted, but the machine itself seems
> >> responsive. I
> >> > >> >>> have
> >> > >> >>> >> >> yet
> >> > >> >>> >> >> to plot the exact submission time for each job.
> >> > >> >>> >> >> So at this point I would recommend trying ws-gram as long
> >> as
> >> > >> >>> there
> >> > >> >>> >> >> aren't too many jobs involved (i.e. under 4000 parallel
> >> jobs),
> >> > >> >>> and
> >> > >> >>> >> >> while
> >> > >> >>> >> >> making sure the jvm has enough heap. More than that seems
> >> like
> >> > >> a
> >> > >> >>> >> >> gamble.
> >> > >> >>> >> >> Mihael
> >> > >> >>> >> >> _______________________________________________
> >> > >> >>> >> >> Swift-devel mailing list
> >> > >> >>> >> >> Swift-devel at ci.uchicago.edu
> >> > >> >>> >> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
