[Swift-devel] ws-gram tests
    feller at mcs.anl.gov
    Fri Feb  8 10:26:26 CST 2008
>> > These are both hacks. I'm not sure I want to go there. 300K per job is
>> a
>> > bit too much considering that swift (which has to consider many more
>> > things) has less than 10K overhead per job.
>> For my better understanding:
>> Do you start up your own notification consumer manager that listens for
>> notifications of all jobs or do you let each GramJob instance listen for
>> notifications itself?
>> In case you listen for notifications yourself: do you store
>> GramJob objects or just EPR's of jobs and create GramJob objects if
>> needed?
> Excellent points. I let each GramJob instance listen for notifications
> itself. What I observed is that it uses only one container for that.
Shoot! i didn't know that and thought there would be a container per
GramJob in that case. That's the core mysteries with notifications.
Anyway: I did a quick check some days ago and found that GramJob is
surprisingly greedy regarding memory as you said. I'll have to further
check what it is, but will probably not do that before 4.2 is out.
> Due to the above, a reference to the GramJob is kept anyway, regardless
> of whether that reference is in client code or the local container.
> I'll try to profile a run and see if I can spot where the problems are.
>> Martin
>> >> The core team will be looking at improving notifications once their
>> >> other 4.2 deliverables are done.
>> >> -Stu
>> >> Begin forwarded message:
>> >> > From: feller at mcs.anl.gov
>> >> > Date: February 1, 2008 9:41:05 AM CST
>> >> > To: "Jaime Frey" <jfrey at cs.wisc.edu>
>> >> > Cc: "Stuart Martin" <smartin at mcs.anl.gov>, "Terrence Martin"
>> >> <tmartin at physics.ucsd.edu
>> >> > >, "Martin Feller" <feller at mcs.anl.gov>, "charles bacon"
>> >> <bacon at mcs.anl.gov
>> >> > >, "Suchandra Thapa" <sthapa at ci.uchicago.edu>, "Rob Gardner"
>> >> <rwg at hep.uchicago.edu
>> >> > >, "Jeff Porter" <rjporter at lbl.gov>, "Alain Roy" <roy at cs.wisc.edu>,
>> >> > "Todd Tannenbaum" <tannenba at cs.wisc.edu>, "Miron Livny"
>> >> <miron at cs.wisc.edu
>> >> > Subject: Re: Condor-G WS GRAM memory usage
>> >> >> On Jan 31, 2008, at 6:26 PM, Jaime Frey wrote:
>> >> >>> On Jan 30, 2008, at 12:25 PM, Stuart Martin wrote:
>> >> >>>> On Jan 30, 2008, at Jan 30, 11:46 AM, Jaime Frey wrote:
>> >> >>>>> Terrence Martin's scalability testing of Condor-G with WS GRAM
>> >> >>>>> raised some concerns about memory usage on the client side. I
>> did
>> >> >>>>> some profiling of Condor-G's WS GRAM GAHP server, which
>> appeared
>> >> >>>>> to be the primary memory consumer. The GAHP server is a wrapper
>> >> >>>>> around the java client libraries for WS GRAM.
>> >> >>>>> In my tests, I submitted variable numbers of jobs up to 30 at a
>> >> >>>>> time. The jobs were 2-minute sleep jobs with minimal data
>> >> >>>>> transfer. All of the jobs overlapped in submission and
>> execution.
>> >> >>>>> Here is what I've discovered so far.
>> >> >>>>> Aside from the heap available to the java code, the jvm used
>> 117
>> >> >>>>> megs of non-shared memory and 74 megs of shared memory.
>> Condor-G
>> >> >>>>> creates one GAHP server for each (local uid, X509 DN) pair.
>> >> >>>>> The maximum jvm heap usage (as reported by the garbage
>> collector)
>> >> >>>>> was about 9 megs plus 0.9 megs per job. When the GAHP was
>> >> >>>>> quiescent (jobs executing, Condor-G waiting for them to
>> complete),
>> >> >>>>> heap usage was about 5 megs plus 0.6 megs per job.
>> >> >>>>> The only long-term memory per job that I know of in the GAHP is
>> >> >>>>> for the notification sink for job status callbacks. 600kb seems
>> a
>> >> >>>>> little high for that. Stu, could someone on Globus help us
>> >> >>>>> determine if we're using the notification sinks inefficiently?
>> >> >>>> Martin just looked and for the most part, there is nothing wrong
>> >> >>>> with how condor-g manages the callback sink.
>> >> >>>> However, one improvement that would reduce the memory used per
>> job
>> >> >>>> would be to not have a notification consumer per job.  Instead
>> use
>> >> >>>> one for all jobs.
>> >> >>>> Also, Martin recently did some analysis on condor-g stress tests
>> >> >>>> and found that notifications are building up on the in the GRAM4
>> >> >>>> service container and that is causing delays which seem to be
>> >> >>>> causing multiple problems.  We're looking at this in a separate
>> >> >>>> effort with the GT Core team.  But, after this was clear, Martin
>> >> >>>> re-
>> >> >>>> ran the condor-g test and relied on polling between condor-g and
>> >> >>>> the GRAM4 service instead of notifications.  Jaime, could you
>> >> >>>> repeat the no-notification test and see the difference in
>> memory?
>> >> >>>> The changes would be to increase the polling frequency in
>> condor-g
>> >> >>>> and comment out the subscribe for notification.  You could also
>> >> >>>> comment out the notification listener call(s) too.
>> >> >>> I did two new sets of tests today. The first used more efficient
>> >> >>> callback code in the GAHP (one notification consumer rather than
>> one
>> >> >>> per job). The second disabled notifications and relied on polling
>> >> >>> for job status changes.
>> >> >>> The more efficient callback code did not produce a noticeable
>> >> >>> reduction in memory usage.
>> >> >>> Disabling notifications did reduce memory usage. The maximum jvm
>> >> >>> heap usage was roughly 8 megs plus 0.5 megs per job. The minimum
>> >> >>> heap usage after job submission and before job completion was
>> about
>> >> >>> 4 megs + 0.1 megs per job.
>> >> >> I ran one more test with the improved callback code. This time, I
>> >> >> stopped storing the notification producer EPRs associated with the
>> >> >> GRAM job resources. Memory usage went down markedly.
>> >> >> I was told the client had to explicitly destroy these serve-side
>> >> >> notification producer resources when it destroys the job,
>> otherwise
>> >> >> they hang around bogging down the server. Is this still the case?
>> The
>> >> >> server can't destroy notification producers when their sources of
>> >> >> information are destroyed?
>> >> > This reminds me of the odd fact that i had to suddenly grant much
>> more
>> >> > memory to Condor-g as soon as condor-g started storing EPRs of
>> >> > subscription resources to be able to destroy them eventually.
>> >> > Those EPR's are maybe not so tiny as they look like.
>> >> > For 4.0: yes, currently you'll have to store and eventually destroy
>> >> > subscription resources manually to avoid heaping up persistence
>> data
>> >> > on the server-side.
>> >> > For 4.2: no, you won't have to store them. A job resource will
>> >> > destroy all subscription resources when it's destroyed.
>> >> > Overall i suggest to concentrate on 4.2 gram since the "container
>> >> > hangs in job destruction" problem won't exist anymore.
>> >> > Sorry, Jaime, i still can't provide you with 100% reliable 4.2
>> changes
>> >> > in Gram in 4.2. I'll do so as soon as i can. I wonder if it makes
>> >> > sense
>> >> > for us to do the 4.2-related changes in Gahp and hand it to you for
>> >> > fine-tuning then?
>> >> > Martin
>> >> On Feb 8, 2008, at Feb 8, 9:19 AM, Ian Foster wrote:
>> >> > Mihael:
>> >> > That's great, thanks!
>> >> > Ian.
>> >> > Mihael Hategan wrote:
>> >> >> I did a 1024 job run today with ws-gram.
>> >> >> I painted the results here:
>> >> >> http://www-unix.mcs.anl.gov/~hategan/s/g.html
>> >> >> Seems like client memory per job is about 370k. Which is quite a
>> lot.
>> >> >> What kinda worries me is that it doesn't seem to go down after the
>> >> >> jobs
>> >> >> are done, so maybe there's a memory leak, or maybe the garbage
>> >> >> collector
>> >> >> doesn't do any major collections. I'll need to profile this to see
>> >> >> exactly what we're talking about.
>> >> >> The container memory is figured by looking at the process in
>> /proc.
>> >> >> It's
>> >> >> total memory including shared libraries and things. But libraries
>> >> >> take a
>> >> >> fixed amount of space, so a fuzzy correlation can probably be
>> made.
>> >> >> It
>> >> >> looks quite similar to the amount of memory eaten on the client
>> side
>> >> >> (per job).
>> >> >> CPU-load-wise, WS-GRAM behaves. There is some work during the time
>> >> >> the
>> >> >> jobs are submitted, but the machine itself seems responsive. I
>> have
>> >> >> yet
>> >> >> to plot the exact submission time for each job.
>> >> >> So at this point I would recommend trying ws-gram as long as there
>> >> >> aren't too many jobs involved (i.e. under 4000 parallel jobs), and
>> >> >> while
>> >> >> making sure the jvm has enough heap. More than that seems like a
>> >> >> gamble.
>> >> >> Mihael
>> >> >> _______________________________________________
>> >> >> Swift-devel mailing list
>> >> >> Swift-devel at ci.uchicago.edu
>> >> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
