[Swift-devel] Re: Swift jobs on UC/ANL TG
Mihael Hategan
hategan at mcs.anl.gov
Mon Feb 4 16:32:32 CST 2008
So WS-GRAM in terms of machine load seems to work better (i.e. barely
visible), which is to be expected. Swift does however run out of memory
faster. Whereas I could safely (from the client side perspective) run
256 parallel jobs with the default 64M of heap space, with WS-GRAM it
dies.
I don't have an exact dependence of load vs. number of jobs yet, but
I'll be working on that.
Mihael
On Mon, 2008-02-04 at 10:48 -0600, Mihael Hategan wrote:
> Yes, and I will. But unless we're completely dropping support for pre-ws
> GRAM, we still need to do this.
> On Mon, 2008-02-04 at 10:31 -0600, Ian Foster wrote:
> > It would be really wonderful if someone can try GRAM4, which we believe
> > addresses this problem.
> > Ian.
> > Ti Leggett wrote:
> > > Then I'd say we have very different levels of acceptable. A simple job
> > > submission test should never take longer than 5 minutes to complete
> > > and a load of 27 is not acceptable when the responsiveness of the
> > > machine is impacted. And since we're having this conversation, there
> > > is a perceived problem on our end so an adjustment to our definition
> > > of acceptable is needed.
> > > On Feb 4, 2008, at 10:18 AM, Mihael Hategan wrote:
> > >> On Mon, 2008-02-04 at 09:58 -0600, Ti Leggett wrote:
> > >>> That inca tests were timing out after 5 minutes and the load on the
> > >>> machine was ~27. How are you concluding when things aren't acceptable?
> > >> It's got 2 cpus. So to me an average load of under 100 and the SSH
> > >> session being responsive looks fine.
> > >> The fact that inca tests are timing out may be because inca has too low
> > >> of a tolerance for things.
> > >>> On Feb 4, 2008, at 9:30 AM, Mihael Hategan wrote:
> > >>>> That's odd. Clearly if that's not acceptable from your perspective,
> > >>>> yet
> > >>>> I thought 130 are fine, there's a disconnect between what you think is
> > >>>> acceptable and what I think is acceptable.
> > >>>> What was that prompted you to conclude things are bad?
> > >>>> On Mon, 2008-02-04 at 07:16 -0600, Ti Leggett wrote:
> > >>>>> Around 80.
> > >>>>> On Feb 4, 2008, at 12:14 AM, Mihael Hategan wrote:
> > >>>>>> On Sun, 2008-02-03 at 22:11 -0800, Mike Kubal wrote:
> > >>>>>>> Sorry for killing the server. I'm pushing to get
> > >>>>>>> results to guide the selection of compounds for
> > >>>>>>> wet-lab testing.
> > >>>>>>> I had set the throttle.score.job.factor to 1 in the
> > >>>>>>> swift.properties file.
> > >>>>>> Hmm. Ti, at the time of the massacre, how many did you kill?
> > >>>>>> Mihael
> > >>>>>>> I certainly appreciate everyone's efforts and
> > >>>>>>> responsiveness.
> > >>>>>>> Let me know what to try next, before I kill again.
> > >>>>>>> Cheers,
> > >>>>>>> Mike
> > >>>>>>> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > >>>>>>>> So I was trying some stuff on Friday night. I guess
> > >>>>>>>> I've found the
> > >>>>>>>> strategy on when to run the tests: when nobody else
> > >>>>>>>> has jobs there
> > >>>>>>>> (besides Buzz doing gridftp tests, Ioan having some
> > >>>>>>>> Falkon workers
> > >>>>>>>> running, and the occasional Inca tests).
> > >>>>>>>> In any event, the machine jumps to about 100%
> > >>>>>>>> utilization at around 130
> > >>>>>>>> jobs with pre-ws gram. So Mike, please set
> > >>>>>>>> 1 in swift.properties.
> > >>>>>>>> There's still more work I need to do test-wise.
> > >>>>>>>> On Sun, 2008-02-03 at 15:34 -0600, Ti Leggett wrote:
> > >>>>>>>>> Mike, You're killing tg-grid1 again. Can someone
> > >>>>>>>> work with Mike to get
> > >>>>>>>>> some swift settings that don't kill our server?
> > >>>>>>>>> On Jan 28, 2008, at 7:13 PM, Mike Kubal wrote:
> > >>>>>>>>>> Yes, I'm submitting molecular dynamics
> > >>>>>>>> simulations
> > >>>>>>>>>> using Swift.
> > >>>>>>>>>> Is there a default wall-time limit for jobs on
> > >>>>>>>> tg-uc?
> > >>>>>>>>>> --- joseph insley <insley at mcs.anl.gov> wrote:
> > >>>>>>>>>>> Actually, these numbers are now escalating...
> > >>>>>>>>>>> top - 17:18:54 up 2:29, 1 user, load
> > >>>>>>>> average:
> > >>>>>>>>>>> 149.02, 123.63, 91.94
> > >>>>>>>>>>> Tasks: 469 total, 4 running, 465 sleeping,
> > >>>>>>>> 0
> > >>>>>>>>>>> stopped, 0 zombie
> > >>>>>>>>>>> insley at tg-grid1:~> ps -ef | grep kubal | wc -l
> > >>>>>>>>>>> 479
> > >>>>>>>>>>> insley at tg-viz-login1:~> time globusrun -a -r
> > >>>>>>>>>>> tg-grid.uc.teragrid.org
> > >>>>>>>>>>> GRAM Authentication test successful
> > >>>>>>>>>>> real 0m26.134s
> > >>>>>>>>>>> user 0m0.090s
> > >>>>>>>>>>> sys 0m0.010s
> > >>>>>>>>>>> On Jan 28, 2008, at 5:15 PM, joseph insley
> > >>>>>>>> wrote:
> > >>>>>>>>>>>> Earlier today tg-grid.uc.teragrid.org (the
> > >>>>>>>> UC/ANL
> > >>>>>>>>>>> TG GRAM host)
> > >>>>>>>>>>>> became unresponsive and had to be rebooted. I
> > >>>>>>>> am
> > >>>>>>>>>>> now seeing slow
> > >>>>>>>>>>>> response times from the Gatekeeper there
> > >>>>>>>> again.
> > >>>>>>>>>>> Authenticating to
> > >>>>>>>>>>>> the gatekeeper should only take a second or
> > >>>>>>>> two,
> > >>>>>>>>>>> but it is
> > >>>>>>>>>>>> periodically taking up to 16 seconds:
> > >>>>>>>>>>>> real 0m16.096s
> > >>>>>>>>>>>> user 0m0.060s
> > >>>>>>>>>>>> sys 0m0.020s
> > >>>>>>>>>>>> looking at the load on tg-grid, it is rather
> > >>>>>>>> high:
> > >>>>>>>>>>>> top - 16:55:26 up 2:06, 1 user, load
> > >>>>>>>> average:
> > >>>>>>>>>>> 89.59, 78.69, 62.92
> > >>>>>>>>>>>> Tasks: 398 total, 20 running, 378 sleeping,
> > >>>>>>>> 0
> > >>>>>>>>>>> stopped, 0 zombie
> > >>>>>>>>>>>> And there appear to be a large number of
> > >>>>>>>> processes
> > >>>>>>>>>>> owned by kubal:
> > >>>>>>>>>>>> 380
> > >>>>>>>>>>>> I assume that Mike is using swift to do the
> > >>>>>>>> job
> > >>>>>>>>>>> submission. Is
> > >>>>>>>>>>>> there some throttling of the rate at which
> > >>>>>>>> jobs
> > >>>>>>>>>>> are submitted to
> > >>>>>>>>>>>> the gatekeeper that could be done that would
> > >>>>>>>>>>> lighten this load
> > >>>>>>>>>>>> some? (Or has that already been done since
> > >>>>>>>>>>> earlier today?) The
> > >>>>>>>>>>>> current response times are not unacceptable,
> > >>>>>>>> but
> > >>>>>>>>>>> I'm hoping to
> > >>>>>>>>>>>> avoid having the machine grind to a halt as it
> > >>>>>>>> did
> > >>>>>>>>>>> earlier today.
> > >>>>>>>>>>>> Thanks,
> > >>>>>>>>>>>> joe.
> > >>>>>>>>>>>> joseph a.
> > >>>>>>>>>>>> insley
> > >>>>>>>>>>>> mathematics & computer science division
> > >>>>>>>>>>> (630) 252-5649
> > >>>>>>>>>>>> argonne national laboratory
> > >>>>>>>>>>> (630)
> > >>>>>>>>>>>> 252-5986 (fax)
> > >>>>>>>>>>> joseph a. insley
> > >>>>>>>> (630)
> > >>>>>>>>>>> 252-5649
> > >>>>>>>>>>> (630)
> > >>>>>>>>>>> 252-5986 (fax)
> > >>>>>>> ____________________________________________________________________________________
> > >>>>>>>>>> Be a better friend, newshound, and
> > >>>>>>>>>> know-it-all with Yahoo! Mobile. Try it now.
> > >>>>>>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > >>>>>>>>> Swift-devel mailing list
> > >>>>>>>>> Swift-devel at ci.uchicago.edu
> > >>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > >>>>>>> Never miss a thing. Make Yahoo your home page.
> > >>>>>>> http://www.yahoo.com/r/hs
