[Swift-devel] Swift throttling
    Ben Clifford
    benc at hawaga.org.uk
    Mon Feb  4 10:17:52 CST 2008
On Mon, 4 Feb 2008, Michael Wilde wrote:
> hopefully the slow-start sensing
> algorithms will sense that resource is already under strain and stay at a low
> submission rate.
I don't think it does that at all.
> - we modify the code to enable explicit limits on the algorithm to be set by
> the user, eg:
>  throttle.host.submitlimit - max # jobs that can be queued to a host
>  throttle.host.submitrate - max #jobs/sec that can be queued to a host
>                             (float)
parameters that control thsoe exist already, I think, for the whole
workflow. In the single site case, site specific ones aren't needed
because of that. If they were being implemented, it would probably be
better to make them settable in the sites catalog so that they can be
defined differently for each site.
throttle.scote.job.factor limits the number of concurrent jobs to 2 +
100*throttle.score.job.factor   (so to achieve a limit of 52, set
throttle.score.job.factor to 0.5)
There's a per-site profile setting:
maxSubmitRate - limits the maximum rate of job submission, in jobs per
second.
