[Swift-devel] Re: Swift jobs on UC/ANL TG
    Ti Leggett
    leggett at mcs.anl.gov
    Mon Feb  4 09:58:40 CST 2008
That inca tests were timing out after 5 minutes and the load on the
machine was ~27. How are you concluding when things aren't acceptable?
On Feb 4, 2008, at 9:30 AM, Mihael Hategan wrote:
> That's odd. Clearly if that's not acceptable from your perspective,
> yet
> I thought 130 are fine, there's a disconnect between what you think is
> acceptable and what I think is acceptable.
> What was that prompted you to conclude things are bad?
> On Mon, 2008-02-04 at 07:16 -0600, Ti Leggett wrote:
>> Around 80.
>> On Feb 4, 2008, at 12:14 AM, Mihael Hategan wrote:
>>> On Sun, 2008-02-03 at 22:11 -0800, Mike Kubal wrote:
>>>> Sorry for killing the server. I'm pushing to get
>>>> results to guide the selection of compounds for
>>>> wet-lab testing.
>>>> I had set the throttle.score.job.factor to 1 in the
>>>> swift.properties file.
>>> Hmm. Ti, at the time of the massacre, how many did you kill?
>>> Mihael
>>>> I certainly appreciate everyone's efforts and
>>>> responsiveness.
>>>> Let me know what to try next, before I kill again.
>>>> Cheers,
>>>> Mike
>>>> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>>>> So I was trying some stuff on Friday night. I guess
>>>>> I've found the
>>>>> strategy on when to run the tests: when nobody else
>>>>> has jobs there
>>>>> (besides Buzz doing gridftp tests, Ioan having some
>>>>> Falkon workers
>>>>> running, and the occasional Inca tests).
>>>>> In any event, the machine jumps to about 100%
>>>>> utilization at around 130
>>>>> jobs with pre-ws gram. So Mike, please set
>>>>> 1 in swift.properties.
>>>>> There's still more work I need to do test-wise.
>>>>> On Sun, 2008-02-03 at 15:34 -0600, Ti Leggett wrote:
>>>>>> Mike, You're killing tg-grid1 again. Can someone
>>>>> work with Mike to get
>>>>>> some swift settings that don't kill our server?
>>>>>> On Jan 28, 2008, at 7:13 PM, Mike Kubal wrote:
>>>>>>> Yes, I'm submitting molecular dynamics
>>>>> simulations
>>>>>>> using Swift.
>>>>>>> Is there a default wall-time limit for jobs on
>>>>> tg-uc?
>>>>>>> --- joseph insley <insley at mcs.anl.gov> wrote:
>>>>>>>> Actually, these numbers are now escalating...
>>>>>>>> top - 17:18:54 up  2:29,  1 user,  load
>>>>> average:
>>>>>>>> 149.02, 123.63, 91.94
>>>>>>>> Tasks: 469 total,   4 running, 465 sleeping,
>>>>> 0
>>>>>>>> stopped,   0 zombie
>>>>>>>> insley at tg-grid1:~> ps -ef | grep kubal | wc -l
>>>>>>>>   479
>>>>>>>> insley at tg-viz-login1:~> time globusrun -a -r
>>>>>>>> tg-grid.uc.teragrid.org
>>>>>>>> GRAM Authentication test successful
>>>>>>>> real    0m26.134s
>>>>>>>> user    0m0.090s
>>>>>>>> sys     0m0.010s
>>>>>>>> On Jan 28, 2008, at 5:15 PM, joseph insley
>>>>> wrote:
>>>>>>>>> Earlier today tg-grid.uc.teragrid.org (the
>>>>> UC/ANL
>>>>>>>> TG GRAM host)
>>>>>>>>> became unresponsive and had to be rebooted.  I
>>>>> am
>>>>>>>> now seeing slow
>>>>>>>>> response times from the Gatekeeper there
>>>>> again.
>>>>>>>> Authenticating to
>>>>>>>>> the gatekeeper should only take a second or
>>>>> two,
>>>>>>>> but it is
>>>>>>>>> periodically taking up to 16 seconds:
>>>>>>>>> real    0m16.096s
>>>>>>>>> user    0m0.060s
>>>>>>>>> sys     0m0.020s
>>>>>>>>> looking at the load on tg-grid, it is rather
>>>>> high:
>>>>>>>>> top - 16:55:26 up  2:06,  1 user,  load
>>>>> average:
>>>>>>>> 89.59, 78.69, 62.92
>>>>>>>>> Tasks: 398 total,  20 running, 378 sleeping,
>>>>> 0
>>>>>>>> stopped,   0 zombie
>>>>>>>>> And there appear to be a large number of
>>>>> processes
>>>>>>>> owned by kubal:
>>>>>>>>>  380
>>>>>>>>> I assume that Mike is using swift to do the
>>>>> job
>>>>>>>> submission.  Is
>>>>>>>>> there some throttling of the rate at which
>>>>> jobs
>>>>>>>> are submitted to
>>>>>>>>> the gatekeeper that could be done that would
>>>>>>>> lighten this load
>>>>>>>>> some?  (Or has that already been done since
>>>>>>>> earlier today?)  The
>>>>>>>>> current response times are not unacceptable,
>>>>> but
>>>>>>>> I'm hoping to
>>>>>>>>> avoid having the machine grind to a halt as it
>>>>> did
>>>>>>>> earlier today.
>>>>>>>>> Thanks,
>>>>>>>>> joe.
>>>>>>>>> joseph a.
>>>>>>>>> insley
>>>>>>>>> mathematics & computer science division
>>>>>>>> (630) 252-5649
>>>>>>>>> argonne national laboratory
>>>>>>>>     (630)
>>>>>>>>> 252-5986 (fax)
>>>>>>>> joseph a. insley
>>>>> (630)
>>>>>>>> 252-5649
>>>>>>>>   (630)
>>>>>>>> 252-5986 (fax)
>>>> ____________________________________________________________________________________
>>>>>>> Be a better friend, newshound, and
>>>>>>> know-it-all with Yahoo! Mobile.  Try it now.
>>>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>>>> Never miss a thing.  Make Yahoo your home page.
>>>> http://www.yahoo.com/r/hs
