[Swift-devel] Re: shared filesystem or work directory ?
    Mats Rynge
    rynge at renci.org
    Fri Dec 26 14:11:05 CST 2008
Ben Clifford wrote:
> In a private message you indicated some suspiciouon about initial working
> directories being wrong. So I investigated and found that at least on
> red.unl.edu the initial working directory of a job is not the directory
> specified in Swift.
Is the problem that the (directory=) RSL is being ignored?
> Below is a url for a rough patch I just made that will explicitly set the
> initial directory.
> Apply it by going into your vdsk directory and typing
> patch -p3 < condor-pwd-bug
> and then rebuilding with ant redist
> This makes submission to red.unl.edu/condor work for me and might make
> other sites work too. Please send feedback to the list...
> http://www.ci.uchicago.edu/~benc/tmp/condor-pwd-bug
Mats Rynge
Renaissance Computing Institute <http://www.renci.org>
