[Swift-devel] ssh data provider
Ben Clifford
benc at hawaga.org.uk
Thu Dec 11 16:25:15 CST 2008
On Thu, 11 Dec 2008, Zhao Zhang wrote:
> I am trying to make the ssh data provider working between BG login node and IO
> node.
> In this context, we could ssh from login nodes to IO nodes without a
> passphrase.
Have you had the ssh provider work in any other situation? It might be
useful to check that you are using it correctly between two standard linux
boxes first.
Can you ssh from the command-line ssh utility from that login node to that
IO node using those credentials? If so, please paste the entire output of
sshing using the -v parameter.
