[Swift-devel] [Bug 160] New: some mappers fail for complex data
bugzilla-daemon at mcs.anl.gov
Mon Dec 8 14:46:50 CST 2008
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=160
Summary: some mappers fail for complex data
Product: Swift
Version: unspecified
Platform: PC
OS/Version: Linux
Status: NEW
Severity: normal
Priority: P2
Component: SwiftScript language
AssignedTo: benc at hawaga.org.uk
ReportedBy: hategan at mcs.anl.gov
when using structures with arrays of arrays, both the filesys and ext mappers
cause consistency check failures.
Here's a test case:
type file{}
type FVec {
file columns[];
type FMat {
FVec rows[];
app (file r) dummy() {
echo "x" stdout=@r;
FMat m <filesys_mapper;prefix="bla">;
m.rows[0].columns[0] = dummy();
This should at least complete successfully. Instead, I see the following error:
Execution failed:
Mapper failed to map org.griphyn.vdl.mapping.DataNode identifier
tag:benc at ci.uchicago.edu,2008:swift:dataset:20081208-1441-2nuvzaa8:720000000008
with no value at dataset=m path=.rows[0].columns[0] (not closed)
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are the assignee for the bug, or are watching the assignee.
