[Swift-devel] a couple of file staging management ideas in the next 3 months
Ioan Raicu
iraicu at cs.uchicago.edu
Tue Dec 2 14:53:37 CST 2008
Ben and I are meeting on Thursday to hopefully flesh out some of these
concrete things. We'll send out a follow-up message then.
Ioan
Mihael Hategan wrote:
> I'm a bit fuzzy on the kind of generic changes that would facilitate the
> move to Falkon. I'd rather like to see the concrete things that are
> needed.
> On Tue, 2008-12-02 at 19:55 +0000, Ben Clifford wrote:
>> Here are a couple of ideas that might be useful to implement over the next
>> three months.
>> This is intended to be read in context of two previous notes documenting
>> what I think is the abstract model that SwiftScript provides, and the
>> present Swift implementation of that.
>> These notes refer to changes that could reasonably be made to the
>> production Swift in the next ~3 months, to both facilitate the
>> experimental side of things (i.e. Falkon) and to broaden the range of
>> sites which Swift could be used on in production (i.e. gLite).
>> Specifically, they are not intended discuss approaches to architecting
>> Falkon, other than to discuss how approaches in Falkon might be coherently
>> interfaced to Swift.
>> Two distinct approaches (which are complimentary and could both
>> implemented) seem feasible to implement in the next two months and
>> interesting at the Swift layer (in as much as they facilitate ongoing
>> work):
>> * change wrapper.sh to access the shared filesystem in various
>> selectable/configurable/pluggable ways; keep everything else the same.
>> So, this changes the requirement that wrapper.sh have posix access to
>> the site cache into a requirement that there is command-line scriptable
>> access to the site cache.
>> This would facilitate gLite's model of no posix access to the site
>> storage system without radically changing architecture. Some OSG users
>> have suggested that this is desirable on OSG.
>> * Fiddle with the abstraction at the execute2 layer
>> execute2 is a routine in the Swift library that selects a site,
>> and then causes stagein to site shared directory, execution on the
>> remote site, and stageout from that site to occur.
>> This layer could be adjusted so the sequence: stagein/execute/stageout
>> is pluggable. By default the exist implementation would be used; but it
>> would allow other code to be plugged in that could replace both the
>> existing client site stagein/execute/stageout code and the remote
>> wrapper.sh code. This would facilitate running in environments where
>> the same underlying layer wants to do both data management and
>> execution management (such as falkon)
>> In the falkon case, what is now provider-deef would plug in at this
>> level and offload all staging responsibility from core Swift.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20081202/a5b22e0f/attachment.html>
