[Swift-devel] several alternatives to design the data management system for Swift on SuperComputers
Zhao Zhang
zhaozhang at uchicago.edu
Mon Dec 1 16:15:54 CST 2008
Hi, All
The following alternatives is a summary from a talk between Mike and
Zhao. We are trying
to optimize the data IO performance for swift on supercomputers,
includes BGP, Ranger,
and possibly Jaguar. We are trying to eliminate all unnecessary data IO
during stages of computation.
Scenario 1: Say a computation has 2 stages, the 2nd stage would take the
output from the 1st stage
as the input data.
Data Flow in current swift system: 1st stage will write the output data
to GPFS, where swift knows this
output data is the input for the 2nd stage. Then send the task to on
worker on CN.
Desired Data Flow: 1st stage of computation knows the output data will
be used as the input for the next
stage, thus the data is not copied back to GPFS, then the 2nd stage task
arrived and consumed this data.
Key Issue: the 2nd stage task has no idea of where the 1st stage output
data is.
Design Alternatives:
1. Data aware task scheduling:
Both swift and falkon need to be data aware. Swift should know where
the output of 1st stage is, which
means, which pset, or say which falkon service.
And the falkon service should know which CN has the data for the 2nd
stage computation.
2. Swift patch jobs vertically
Before sending out any jobs, swift knows those 2 stage jobs has data
dependency, thus send out 1 batched
job as 1 to each worker.
3. Collective IO
Build a shared file system which could be accessed by all CN, instead
of writing output data to GPFS, workers
copy intermediate output data to this shared ram-disk. And retrieve
the data from IFS.
Several Concerns:
a) reliability of torus network --- we need to test more about this.
b) performance of torus network --- could this be really performing
better than GPFS? If not, at what scale
could torus perform better than GPFS?
4. Half-Collective IO
All workers wirte data to IFS, and the data will be periodically
copied back to GPFS. In this case, we only
optimize the output phase, leave the input phase as is.
Any other ideas? Thanks so much.
best wishes
zhangzhao
