[Swift-devel] not able to resume
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Aug 18 17:56:12 CDT 2008
On Mon, 2008-08-18 at 17:47 -0500, skenny at uchicago.edu wrote:
> hmm, looks like the rlog got deleted...for future reference
> though, do you know how i might be able to tell that from the
> rlog?
If it's empty, it means it hasn't recorded anything.
> ---- Original message ----
> >Date: Mon, 18 Aug 2008 17:09:15 -0500
> >From: Mihael Hategan <hategan at mcs.anl.gov>
> >Subject: Re: [Swift-devel] not able to resume
> >To: skenny at uchicago.edu
> >Cc: Ben Clifford <benc at HAWAGA.ORG.UK>,
> swift-devel at ci.uchicago.edu
> >Seems to be working fine.
> >Perhaps you are running, in your failed restarts, into the
> "staging out
> >happens late" issue. Can you send a sample rlog?
> >On Mon, 2008-08-18 at 17:04 -0500, skenny at uchicago.edu wrote:
> >> ok, now i get similar output to the others for restart3, not
> >> sure what happened there; but here's the whole output:
> >> [skenny at andrew misc]$ ./restart3.sh
> >> Swift svn swift-r2185 cog-r2128
> >> RunID: 20080818-1703-z57hx8j2
> >> Progress:
> >> helperA started
> >> Sorted: [localhost:0.000(1.000):0/1 overload: 0]
> >> helperA completed
> >> helperB started
> >> Sorted: [localhost:1.303(2.111):0/1 overload: 0]
> >> Sorted: [localhost:1.595(2.473):0/1 overload: 0]
> >> Sorted: [localhost:1.888(2.882):0/1 overload: 0]
> >> helperB failed
> >> Execution failed:
> >>         Exception in helperB:
> >> Arguments: [restart-2.out]
> >> Host: localhost
> >> Directory:
> restart3-20080818-1703-z57hx8j2/jobs/q/helperB-quat76yi
> >> stderr.txt:
> >> stdout.txt:
> >> Caused by:
> >>         Exit code 1
> >> RunID: 20080818-1703-bhfsb6be
> >> Progress:
> >> helperB started
> >> helperB completed
> >> helperC started
> >> helperC completed
> >> Final status:  Initializing:1 Finished successfully:2
> >> success
