[Swift-devel] not able to resume
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Aug 18 17:09:15 CDT 2008
Seems to be working fine.
Perhaps you are running, in your failed restarts, into the "staging out
happens late" issue. Can you send a sample rlog?
On Mon, 2008-08-18 at 17:04 -0500, skenny at uchicago.edu wrote:
> ok, now i get similar output to the others for restart3, not
> sure what happened there; but here's the whole output:
> [skenny at andrew misc]$ ./restart3.sh
> Swift svn swift-r2185 cog-r2128
> RunID: 20080818-1703-z57hx8j2
> Progress:
> helperA started
> Sorted: [localhost:0.000(1.000):0/1 overload: 0]
> helperA completed
> helperB started
> Sorted: [localhost:1.303(2.111):0/1 overload: 0]
> Sorted: [localhost:1.595(2.473):0/1 overload: 0]
> Sorted: [localhost:1.888(2.882):0/1 overload: 0]
> helperB failed
> Execution failed:
>         Exception in helperB:
> Arguments: [restart-2.out]
> Host: localhost
> Directory: restart3-20080818-1703-z57hx8j2/jobs/q/helperB-quat76yi
> stderr.txt:
> stdout.txt:
> Caused by:
>         Exit code 1
> RunID: 20080818-1703-bhfsb6be
> Progress:
> helperB started
> helperB completed
> helperC started
> helperC completed
> Final status:  Initializing:1 Finished successfully:2
> success
