[Swift-devel] not able to resume
    skenny at uchicago.edu
    Mon Aug 18 16:49:40 CDT 2008
restart: success (w/errors during run)
restart2: success (w/errors)
restart3:
[skenny at andrew misc]$ ./restart3.sh
Could not start execution.
        Error reading source:  : input contained no data
Failed - second round did not exit with success
restart4: success (w/errors)
restart5: success (w/errors)
restart-extern: success (w/errors)
restart-iterate: success (w/errors)
for all of the ones with errors, it seems to be helperB:
helperB failed
Final status:  Failed:1 Finished successfully:1
The following errors have occurred:
1. Application "helperB" failed (Exit code 1)
        Arguments:
"/disks/gpfs/fmri/cnari/swift/sbuilds/cog/modules/vdsk/tests/misc/restart-extern.2.out,
/etc/group, baz"
        Host: localhost
        Directory:
restart-extern-20080818-1643-bofrdg7f/jobs/c/helperB-c6x176yi
        STDERR:
        STDOUT:
Swift svn swift-r2185 cog-r2128
let me know if it helps to paste the entire output for any/all
of these. i'm not quite sure what 'success' means given there
are errors during the test (?)
thanks
sarah
---- Original message ----
>Date: Fri, 15 Aug 2008 21:02:31 +0000 (GMT)
>From: Ben Clifford <benc at HAWAGA.ORG.UK>
>Subject: Re: [Swift-devel] not able to resume
>To: skenny at uchicago.edu
>Cc: swift-devel at ci.uchicago.edu
>In tests/misc/ there are a number of tests for restarts -
restart*.sh
>Run those against your build (by putting Swift in your path
and typing eg:
>./restart.sh
>./restart-iterate.sh
>etc
>and see what results you get - each test will output either a
failure
>message or "success" as the last line.
