[Swift-devel] swift 0.6 rc5
    Ben Clifford
    benc at hawaga.org.uk
    Wed Aug  6 11:13:19 CDT 2008
Once again its time to try a release candidate for 0.6.
http://www.ci.uchicago.edu/~benc/vdsk-0.6-rc5.tar.gz
Please test and report.
It is built with coasters and provider-wonky both turned enabled.
I ran the site tests and got these results:
These sites failed: fletch-condor-gram2.xml osg-edu.cs.wisc.edu-condor.xml
tgncsa-hg-pbs-gram4.xml tgpurdue-condor-gram2.xml
tgpurdue-condor-gram4.xml tgtacc-fork-gram2.xml tgtacc-lsf-gram2.xml
UCLA_Saxon_Tier3-fork.xml
These sites worked: fletch-fork-gram2.xml osg-edu.cs.wisc.edu-fork.xml
tgncsa-hg-fork-gram2.xml tgncsa-hg-fork-gram4.xml tgncsa-hg-pbs-gram2.xml
tgpurdue-fork-gram2.xml tgpurdue-fork-gram4.xml tguc-fork-gram2.xml
tguc-fork-gram4.xml tguc-pbs-gram2-syntax1.xml tguc-pbs-gram2.xml
tguc-pbs-gram4.xml tp-fork-gram2.xml tp-fork-gram4.xml tp-pbs-gram2.xml
Nothing looks too tragic there; I'll investigate the failures later but
they all look like site-specific problems, not swift problems.
During local testing on communicado, I once saw one of the tests hang in
initialising site state, but was unable to get that to reappear. So I
think there's something fishy still going on with load management/site
selection but not excessively bad.
