[Swift-devel] [Bug 152] filesys_mapper gives exception
    bugzilla-daemon at mcs.anl.gov
    Mon Aug  4 12:25:59 CDT 2008
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=152
------- Comment #4 from benc at hawaga.org.uk  2008-08-04 12:25 -------
Difference in the run you give and the run I tried that appears to cause the
problem is that the single file mapped in your case has a name that consists
entirely of the suffix, with no base filename on it. That probably should be
made to work. However it is suggestive that this is a different exception to
what you got with more than one file, given that only one file can exist where
the name consists only of the suffix.
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
You reported the bug, or are watching the reporter.
