[Swift-devel] code to test for file existence in swift
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Apr 25 10:19:34 CDT 2008
Mike, could you elaborate on the use case for this?
Do you want the swift code to execute a procedure only if a file exists?
Exists on the submit host?
One way is write a tiny shell script that returns 1 or True if the file
exists and zero otherwise.  You'll need, I think, to use @extractint:
the return value (from the test) in fact needs to go into a file, then
extractint can return t/f based on the value of that file:
@extractint(file) will read the specified file, parse an integer from
the file contents and return that integer.
if, switch or iterate could then be used to act on the
exists/doesnt-exist condition.
I'm not sure if there's a more elegant way to do this. Depends a bit on
your actual use case.
- Mike
On 4/25/08 10:08 AM, Mike Kubal wrote:
> Could someone suggest swift code for testing for the
> existence of a file?
> Thanks,
> Mike
>       ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
