[Swift-devel] Re: Another performance comparison of DOCK
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Apr 13 17:06:11 CDT 2008
On Sun, 2008-04-13 at 17:50 -0500, Michael Wilde wrote:
> Its not clear to me whats best here, for 3 reasons:
> 1) We should set file.transfers and file.operations to a value that
> prevents Swift from adversely impacting performance on shared resources.
> Since Swift must run on the login node and hits the shared cluster
> networks, we should test carefully.
> 2) Its not clear to me how many concurrent operations the login hosts
> can sustain before topping out, and how this number depends on file
> size. Do you know this from the GPFS benchmarks? And did you measure
> impact on system response during those benchmarks?
> I think that the overall system would top out well before 2000
> concurrent transfers, but I could be wrong. Going much higher than the
> point where concurrency increases the data rate, it seems, would cause
> the rate to drop due to contention and context switching.
The number is probably in the 10-100 range. With 2000 it's somewhat
likely that the transfers are long done before all the gridftp
connections can be started.
Mihael
> 3) If I/O operations are fast compared to the job length and completion
> rate, you dont have to set these values to the same as the max number of
> input files that can be demanded at once.
> I think we want to set the I/O operation concurrency to a value that
> achieves the highest operation rate we can sustain while keeping overall
> system performance at some acceptable level (tbd).
> So first we need to find the concurrency level that maximizes ops/sec,
> (which may be filesize dependent) and then possibly back that off to
> reduce system impact.
> It seems to me that finding the right I/O concurrency setting is complex
> and non-obvious, and I'm interested in what Ben and Mihael suggest here.
> - Mike
> On 4/13/08 3:51 PM, Ioan Raicu wrote:
> > But we have 2X input files as opposed to number of jobs and CPUs.  We
> > have 2048 CPUs, shouldn't we set all file I/O operations to at least
> > 4096... and that means that files won't be ready for the next jobs once
> > the first ones start completing... so we should really set things to
> > twice that, so 8192 is the number I'd set on all file operations for
> > this app on 2K CPUs.
> > Ioan
> > Zhao Zhang wrote:
> >> Hi, Mike
> >>> Ben, your analysis sounds very good. Some notes below, including
> >>> questions for Zhao.
> >>> On 4/13/08 2:57 PM, Ben Clifford wrote:
> >>>>> Ben, can you point me to the graphs for this run? (Zhao's
> >>>>> *99cy0z4g.log)
> >>>> http://www.ci.uchicago.edu/~benc/report-dock2-20080412-1609-99cy0z4g
> >>>>> Once stage-ins start to complete, are the corresponding jobs
> >>>>> initiated quickly, or is Swift doing mostly stage-ins for some period?
> >>>> In the run dock2-20080412-1609-99cy0z4g, jobs are submitted (to
> >>>> falkon) pretty much right as the corresponding stagein completes. I
> >>>> have no deeper information about when the worker actually starts to
> >>>> run.
> >>>>> Zhao indicated he saw data indicating there was about a 700 second
> >>>>> lag from
> >>>>> workflow start time till the first Falkon jobs started, if I
> >>>>> understood
> >>>>> correctly. Do the graphs confirm this or say something different?
> >>>> There is a period of about 500s or so until stuff starts to happen;
> >>>> I haven't looked at it. That is before stage-ins start too, though,
> >>>> which means that i think this...
> >>>>> If the 700-second delay figure is true, and stage-in was eliminated
> >>>>> by copying
> >>>>> input files right to the /tmp workdir rather than first to /shared,
> >>>>> then we'd
> >>>>> have:
> >>>>> 1190260 / ( 1290 * 2048 ) = .45 efficiency
> >>>> calculation is not meaningful.
> >>>> I have not looked at what is going on during that 500s startup time,
> >>>> but I plan to.
> >>> Zhao, what SVN rev is your Swift at?  Ben fixed an N^2 mapper logging
> >>> problem a few weeks ago. Could that cause such a delay, Ben? It would
> >>> be very obvious in the swift log.
> >> The version is Swift svn swift-r1780 cog-r1956
> >>>>> I assume we're paying the same staging price on the output side?
> >>>> not really - the output stageouts go very fast, and also because job
> >>>> ending is staggered, they don't happen all at once.
> >>>> This is the same with most of the large runs I've seen (of any
> >>>> application) - stageout tends not to be a problem (or at least, no
> >>>> where near the problems of stagein).
> >>>> All stageins happen over a period t=400 to t=1100 fairly smoothly.
> >>>> There's rate limiting still on file operations (100 max) and file
> >>>> transfers (2000 max) which is being hit still.
> >>> I thought Zhao set file operations throttle to 2000 as well.  Sounds
> >>> like we can test with the latter higher, and find out what's limiting
> >>> the former.
> >>> Zhao, what are your settings for property throttle.file.operations?
> >>> I assume you have throttle.transfers set to 2000.
> >>> If its set right, any chance that Swift or Karajan is limiting it
> >>> somewhere?
> >> 2000 for sure,
> >> throttle.submit=off
> >> throttle.host.submit=off
> >> throttle.score.job.factor=off
> >> throttle.transfers=2000
> >> throttle.file.operation=2000
> >>>> I think there's two directions to proceed in here that make sense
> >>>> for actual use on single clusters running falkon (rather than trying
> >>>> to cut out stuff randomly to push up numbers):
> >>>>  i) use some of the data placement features in falkon, rather than
> >>>> Swift's
> >>>>     relatively simple data management that was designed more for
> >>>> running
> >>>>     on the grid.
> >>> Long term: we should consider how the Coaster implementation could
> >>> eventually do a similar data placement approach. In the meantime (mid
> >>> term) examining what interface changes are needed for Falkon data
> >>> placement might help prepare for that. Need to discuss if that would
> >>> be a good step or not.
> >>>>  ii) do stage-ins using symlinks rather than file copying. this makes
> >>>>      sense when everything is living in a single filesystem, which
> >>>> again
> >>>>      is not what Swift's data management was originally optimised for.
> >>> I assume you mean symlinks from shared/ back to the user's input files?
> >>> That sounds worth testing: find out if symlink creation is fast on
> >>> NFS and GPFS.
> >>> Is another approach to copy direct from the user's files to the /tmp
> >>> workdir (ie wrapper.sh pulls the data in)? Measurement will tell if
> >>> symlinks alone get adequate performance. Symlinks do seem an easier
> >>> first step.
> >>>> I think option ii) is substantially easier to implement (on the
> >>>> order of days) and is generally useful in the single-cluster,
> >>>> local-source-data situation that appears to be what people want to
> >>>> do for running on the BG/P and scicortex (that is, pretty much
> >>>> ignoring anything grid-like at all).
> >>> Grid-like might mean pulling data to the /tmp workdir directly by the
> >>> wrapper - but that seems like a harder step, and would need
> >>> measurement and prototyping of such code before attempting. Data
> >>> transfer clients that the wrapper script can count on might be an
> >>> obstacle.
> >>>> Option i) is much harder (on the order of months), needing a very
> >>>> different interface between Swift and Falkon than exists at the moment.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
