[Swift-devel] Re: Another performance comparison of DOCK
Michael Wilde wilde at mcs.anl.gov
Sun Apr 13 15:35:23 CDT 2008
Ben, your analysis sounds very good. Some notes below, including
questions for Zhao.
On 4/13/08 2:57 PM, Ben Clifford wrote:
>> Ben, can you point me to the graphs for this run? (Zhao's *99cy0z4g.log)
> http://www.ci.uchicago.edu/~benc/report-dock2-20080412-1609-99cy0z4g
>> Once stage-ins start to complete, are the corresponding jobs initiated
>> quickly, or is Swift doing mostly stage-ins for some period?
> In the run dock2-20080412-1609-99cy0z4g, jobs are submitted (to falkon)
> pretty much right as the corresponding stagein completes. I have no deeper
> information about when the worker actually starts to run.
>> Zhao indicated he saw data indicating there was about a 700 second lag from
>> workflow start time till the first Falkon jobs started, if I understood
>> correctly. Do the graphs confirm this or say something different?
> There is a period of about 500s or so until stuff starts to happen; I
> haven't looked at it. That is before stage-ins start too, though, which
> means that i think this...
>> If the 700-second delay figure is true, and stage-in was eliminated by copying
>> input files right to the /tmp workdir rather than first to /shared, then we'd
>> have:
>> 1190260 / ( 1290 * 2048 ) = .45 efficiency
> calculation is not meaningful.
> I have not looked at what is going on during that 500s startup time, but I
> plan to.
Zhao, what SVN rev is your Swift at?  Ben fixed an N^2 mapper logging
problem a few weeks ago. Could that cause such a delay, Ben? It would be
very obvious in the swift log.
>> I assume we're paying the same staging price on the output side?
> not really - the output stageouts go very fast, and also because job
> ending is staggered, they don't happen all at once.
> This is the same with most of the large runs I've seen (of any
> application) - stageout tends not to be a problem (or at least, no where
> near the problems of stagein).
> All stageins happen over a period t=400 to t=1100 fairly smoothly. There's
> rate limiting still on file operations (100 max) and file transfers (2000
> max) which is being hit still.
I thought Zhao set file operations throttle to 2000 as well.  Sounds
like we can test with the latter higher, and find out what's limiting
the former.
Zhao, what are your settings for property throttle.file.operations?
I assume you have throttle.transfers set to 2000.
If its set right, any chance that Swift or Karajan is limiting it somewhere?
> I think there's two directions to proceed in here that make sense for
> actual use on single clusters running falkon (rather than trying to cut
> out stuff randomly to push up numbers):
>  i) use some of the data placement features in falkon, rather than Swift's
>     relatively simple data management that was designed more for running
>     on the grid.
Long term: we should consider how the Coaster implementation could
eventually do a similar data placement approach. In the meantime (mid
term) examining what interface changes are needed for Falkon data
placement might help prepare for that. Need to discuss if that would be
a good step or not.
>  ii) do stage-ins using symlinks rather than file copying. this makes
>      sense when everything is living in a single filesystem, which again
>      is not what Swift's data management was originally optimised for.
I assume you mean symlinks from shared/ back to the user's input files?
That sounds worth testing: find out if symlink creation is fast on NFS
and GPFS.
Is another approach to copy direct from the user's files to the /tmp
workdir (ie wrapper.sh pulls the data in)? Measurement will tell if
symlinks alone get adequate performance. Symlinks do seem an easier
first step.
> I think option ii) is substantially easier to implement (on the order of
> days) and is generally useful in the single-cluster, local-source-data
> situation that appears to be what people want to do for running on the
> BG/P and scicortex (that is, pretty much ignoring anything grid-like at
> all).
Grid-like might mean pulling data to the /tmp workdir directly by the
wrapper - but that seems like a harder step, and would need measurement
and prototyping of such code before attempting. Data transfer clients
that the wrapper script can count on might be an obstacle.
> Option i) is much harder (on the order of months), needing a very
> different interface between Swift and Falkon than exists at the moment.
