[Swift-devel] Re: Another performance comparison of DOCK
Zhao Zhang
zhaozhang at uchicago.edu
Sat Apr 12 16:46:18 CDT 2008
Hi, Ioan
Check the log file at BGP,
/home/falkon/DOCK_swift+falkon/DOCK_swift+falkon_4x512_6084_2008.04.12_15.38.31
I ran 6084 DOCK tasks, and it indeed runs on 2048 cores.
zhao
Michael Wilde wrote:
> Ben, can you confirm this: to turn off all job submission throttling
> (for Falkon), the correct setting for each of the following props is
> "off"?
> # remove all limits on job submit rates
> throttle.submit=off
> throttle.host.submit=off
> throttle.score.job.factor=off
> Long ago (circa Nov) it seemed "off" didn't give the the wide-open
> throttle effect I was looking for, but "off" is a more clear setting
> than "big numbers" if we know it to be working as expected.
> - Mike
> On 4/12/08 5:22 AM, Ben Clifford wrote:
>> On Sat, 12 Apr 2008, Zhao Zhang wrote:
>>> i) what files are shared (so swift will only stage-in once)
>>> how many files per job and how big in total per job?
>>> I am not familiar with definition of "stage-in". Mike, could you
>>> help to
>>> explain this?
>> When a job runs in Swift, it looks like this:
>> stage in the input files - copy the input files from where they are
>> stored to where they are needed for execution
>> execute (using falkon in this case)
>> stage out the output files
>> The execute stage is what falkon is involved in; there are other
>> mechanisms to move files around into the appropraite
>> So really I want to know what are the input files to your jobs.
>>> on GPFS of Blue Gene
>> If everything is on the same filesystem on bluegene, an interesting
>> idea springs to mind of potentially only symlinking the input files
>> rather than copying them around.
>> I can have a play with that next week perhaps.
