[Swift-devel] Re: Another performance comparison of DOCK
    Michael Wilde
    wilde at mcs.anl.gov
    Sat Apr 12 08:45:19 CDT 2008
Ben, can you confirm this: to turn off all job submission throttling
(for Falkon), the correct setting for each of the following props is "off"?
# remove all limits on job submit rates
throttle.submit=off
throttle.host.submit=off
throttle.score.job.factor=off
Long ago (circa Nov) it seemed "off" didn't give the the wide-open
throttle effect I was looking for, but "off" is a more clear setting
than "big numbers" if we know it to be working as expected.
- Mike
On 4/12/08 5:22 AM, Ben Clifford wrote:
> On Sat, 12 Apr 2008, Zhao Zhang wrote:
>>   i) what files are shared (so swift will only stage-in once)
>>        how many files per job and how big in total per job?
>> I am not familiar with definition of "stage-in". Mike, could you help to
>> explain this?
> When a job runs in Swift, it looks like this:
>     stage in the input files - copy the input files from where they are
>        stored to where they are needed for execution
>     execute (using falkon in this case)
>     stage out the output files
> The execute stage is what falkon is involved in; there are other
> mechanisms to move files around into the appropraite
> So really I want to know what are the input files to your jobs.
>> on GPFS of Blue Gene
> If everything is on the same filesystem on bluegene, an interesting idea
> springs to mind of potentially only symlinking the input files rather than
> copying them around.
> I can have a play with that next week perhaps.
