[Swift-devel] coaster status summary
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Sat Apr  5 08:25:36 CDT 2008
I looked around for some docs on the networking structure, but couldn't
find anything.
There are several networks available on the BG/P: Torus, Tree, Barrier,
RAS, 10Gig Ethernet.
Of all these, we are only using the Ethernet network, which allows us to
communicate via TCP/IP (or potentially UDP/IP) between compute nodes and
I/O nodes, or between compute nodes and login nodes.  For the rest of
the discussion, we assume only Ethernet communication.  There is 1 I/O
node per 64 compute nodes (what we call a P-SET), and the I/O node can
only communicate with compute nodes that it manages within the same
P-SET (the 64 nodes).  A compute node from one P-SET cannot directly
communicate with another compute from a different P-SET.  This is
primarily because compute nodes have private addresses (192.168.x.x),
I/O nodes are the NAT between the public IP and the private IP, and the
login nodes only have a public IP.  So, the compute nodes all have the
same IP addresses, 192.168.x.x, and they repeat for every P-SET, and the
I/O nodes handle their traffic in and out.
Zhao, if you have any docs on the Ethernet network and the NAT that sits
on the I/O node, can you please send it to the mailing list?
Ioan
Ben Clifford wrote:
>> it would matter on a machine such as
>> the BG/P, as there is a NAT inbetween the login nodes and the compute nodes.
> wierd. is there a description of that somewhere?
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
