[Swift-devel] coaster status summary
Mihael Hategan
hategan at mcs.anl.gov
Fri Apr 4 04:39:37 CDT 2008
I've been asked for a summary of the status of the coaster prototype, so
here it is:
- It's a prototype so bugs are plenty
- It's self deployed (you don't need to start a service on the target
cluster)
- You can also use it while starting a service on the target cluster
- There is a worker written in Perl
- It uses encryption between client and coaster service
- It uses UDP between the service and the workers (this may prove to be
better or worse choice than TCP)
- A preliminary test done locally shows an amortized throughput of
around 180 jobs/s (/bin/date). This was done with encryption and with 10
workers. Pretty picture attached (total time vs. # of jobs)
To do:
- The scheduling algorithm in the service needs a bit more work
- When worker messages are lost, some jobs may get lost (i.e. needs more
fault tolerance)
- Start testing it on actual clusters
- Do some memory consumption benchmarks
- Better allocation strategy for workers
Mihael
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080404/511fde25/attachment.pdf>
