[Swift-devel] [Bug 92] New: URIs in mappers
bugzilla-daemon at mcs.anl.gov
Mon Sep 24 06:33:17 CDT 2007
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=92
Summary: URIs in mappers
Product: Swift
Version: unspecified
Platform: Macintosh
OS/Version: Mac OS
Status: NEW
Severity: normal
Priority: P2
Component: General
AssignedTo: hategan at mcs.anl.gov
ReportedBy: benc at hawaga.org.uk
CC: swift-devel at ci.uchicago.edu
(this was a message on swift-devel but I've moved it here because it needs
tracking - I'd forgotten about it...
http://mail.ci.uchicago.edu/pipermail/swift-devel/2007-September/001659.html)
I was looking at mappers using URIs in r1227, which I've never tried
before.
I was expecting something like the following program to work (to produce a
copy of the file mapped to the f variable into $PWD/here).
type file;
(file o) cat(file i) {
app {
cat stdin=@i stdout=@o;
file f <"gsiftp://terminable.ci.uchicago.edu/etc/group">;
file out <"here">;
out = cat(f);
When I say
file f <"/etc/group">;
or
file f <"file:///etc/group">;
I get files OK.
However, other uses are less successful:
file://localhost/etc/group dies like this:
Swift v0.2-dev r1227 (modified locally)
RunID: 20070918-1214-7dls8y23
cat started
cat failed
Execution failed:
Exception in cat:
Arguments: []
Host: localhost
Directory: ftptest-20070918-1214-7dls8y23/cat-62kxdehi
stderr.txt:
stdout.txt:
Caused by:
File not found:
/Users/benc/work/cog/modules/vdsk/localhost/etc/group
with http:
file f <"http://www.hawaga.org.uk/ben/index.html">;
gives similar error ending:
File not found: /Users/benc/work/cog/modules/vdsk/ben/index.html
and with gsiftp:
File not found: /Users/benc/work/cog/modules/vdsk/etc/group
(I can get that http URL with wget, and the gsiftp one with g-u-c)
In the gsiftp case, I see that a subdirectory:
/var/tmp/ftptest-20070918-1217-gxh621s5/shared/etc
has been created in the run directory, but no group file has appeared
there.
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
