[Swift-devel] sending your logs to a central place.
    Ben Clifford
    benc at hawaga.org.uk
    Sun Sep 23 15:38:21 CDT 2007
If you have a UC Computation Institute account, run this command in your
submit directory after each run. It will copy all your logs and kickstart
records into a directory at CI so that I can play with making interesting
reports.
rsync --ignore-existing *.log *-kickstart.xml
   terminable.ci.uchicago.edu:/home/benc/swift-logs/ --verbose
