[Swift-devel] Falcon from SVN doesn't build
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Sep 21 11:35:03 CDT 2007
Let me do a clean checkout and try to compile, and get back to you!
BTW, I bet its a classpath problem of some sort, maybe the compile
script has somehow been broken...
Ioan
Veronika Nefedova wrote:
> Ioan,
> I am trying to build Falcon from SVN now on tg-uc. Unfortunatelly, the
> build fails. I have this version of java set in my environment:
> java-1.4.2-r1 and this ant : apache-ant-1.6.5-r1
> I tried to build it on terminable and it also failed (with
> /soft/java-1.5.0_06-sun-r1/bin/java
> and /soft/apache-ant-1.6.5-r1/bin/ant )
> This is just the very beginning of the output, but there are many
> other errors (thats from falcon checkout on terminable)
> Buildfile: build-falkon.xml
> all:
>     [javac] Compiling 22 source files to
> /autonfs/home/nefedova/falkon/service
>     [javac]
> /autonfs/home/nefedova/falkon/service/org/globus/GenericPortal/services/core/WS/impl/ActiveTasks.java:5:
> package org.globus.GenericPortal.stubs.GPService_instance does not exist
>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
>     [javac] ^
>     [javac]
> /autonfs/home/nefedova/falkon/service/org/globus/GenericPortal/services/core/WS/impl/GPResource.java:48:
>     [javac] ^
> <snip>
> Does it build for you? Any suggestions on how make it work?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
