[Swift-devel] bug 53
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Sep 13 17:48:40 CDT 2007
It would be good to have some comparison numbers, so I think its worth
doing to see if the workflow will complete, and to see what performance
it gets!
Ioan
Veronika Nefedova wrote:
> Thanks, Mihael! I could try submitting now some 20 molecules to tg-uc
> (directly to GRAM) -- just to be on a safe side. If no GRAM problems
> will be reported, I'll increase the number to 244.
> Of, course the performance will suffer greatly -- but I hope it would
> enable to get the whole workflow to go throw. Are there any throttles
> that could be set to increase a bit the performance (given that I set
> the maxSubmitRate to 0.2) ?'
> Nika
> On Sep 13, 2007, at 4:41 PM, Mihael Hategan wrote:
>> Ok, so there's something in.
>> There are some discussions that can be had on certain aesthetic topics.
>> In any event, in sites.xml, you can add, for a site, something like
>> this:
>> <profile namespace="karajan" key="maxSubmitRate">0.1</profile>
>> The rate is in jobs per second. The above would mean one job every ten
>> seconds.
>> Mihael
>> On Thu, 2007-09-13 at 15:23 +0000, Ben Clifford wrote:
>>> Yes?
>>> On Thu, 13 Sep 2007, Mihael Hategan wrote:
>>>> May I still fix that bug though?
>>>> On Thu, 2007-09-13 at 09:54 -0500, Ioan Raicu wrote:
>>>>> Hi,
>>>>> I am still working on the new feature for Falkon to avoid submitting
>>>>> tasks to known bad nodes, and to perhaps do its own retries for
>>>>> failed
>>>>> jobs with certain known errors (i.e. stale NFS handle).  I should
>>>>> have
>>>>> that ready for next week to try out.  Once this new feature is in, we
>>>>> could try MolDyn again to see how it behaves.
>>>>> About avoiding Falkon of MolDyn, I recall something about the
>>>>> scalability/policies of GRAM/PBS to handle many con current jobs,
>>>>> having to throttle job submissions to something around 1 job every 10
>>>>> seconds (for sustained periods of time, short bursts could send
>>>>> faster), and the fact that only a few 10s of nodes would be used
>>>>> concurrently, even though the sites that it was running on had more
>>>>> free nodes.  I also think that MolDyn through GRAM/PBS was running
>>>>> only 1 job per node, in essence only using 1 processor of the 2 per
>>>>> node.  I think the largest workflow Nika was able to run over
>>>>> GRAM/PBS
>>>>> was 5 molecules, 421 jobs (but only 340 jobs in the large stage).
>>>>> Nika, were there other problems you encountered?
>>>>> Ioan
>>>>>> Very well Sir. I shall see to the priority of the issue being
>>>>>> raised.
>>>>>> On Thu, 2007-09-13 at 14:09 +0000, Ben Clifford wrote:
>>>>>>> I think one of the main impediments to moldyn running with GRAM
>>>>>>> directly
>>>>>>> is bug 53 which is a request for sumission rate limiting.
>>>>>>> It might be relatively easy to implement that and see how the
>>>>>>> MolDyn
>>>>>>> workflow behaves then.
>>>>>>> I'm interested to see if Falkon can be avoided for this workflow.
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>>>>> Ioan Raicu
>>>>> Ph.D. Student
>>>>> Distributed Systems Laboratory
>>>>> Computer Science Department
>>>>> University of Chicago
>>>>> 1100 E. 58th Street, Ryerson Hall
>>>>> Chicago, IL 60637
>>>>> Email: iraicu at cs.uchicago.edu
>>>>> Web:   http://www.cs.uchicago.edu/~iraicu
>>>>>        http://dsl.cs.uchicago.edu/
Ioan Raicu
Ph.D. Student
Chicago, IL 60637
