[Swift-devel] Formatting kickstart records
Brian Tierney
bltierney at lbl.gov
Tue Sep 11 15:40:04 CDT 2007
Michael Wilde wrote:
> Hi Brian,
> The cheat-sheet page at
> http://www.cedps.net/wiki/index.php/LoggingBestPracticesCheatSheet
> was very helpful.
> We'll need to get a place in the eventname hierarchy - like
> org.globus.swift.* - I assume that's what we should use.
Yes, that sounds right.
> Our timestamps are close in format but use local time with a TZ suffix.
> We could change to GMT (I assume thats what Z means)
correct, its a standard ISO format where Z = GMT
> What's the standard and use for GUIDs? I assume that can be used to tie
> together events across components, but I'm not sure how to make the
> correlation. Swift generates its own GUIDs internally for various
> objects in the lifetime of a workflow (eg jobs).
There is no standard for this. Your own GUID should be fine.
