[Swift-devel] Formatting kickstart records
    Brian Tierney
    bltierney at lbl.gov
    Tue Sep 11 11:47:11 CDT 2007
Hi Mike:
The logging document is here:
http://www.cedps.net/wiki/index.php/LoggingBestPractices
and a paper describing the higher-level vision is here:
http://www.cedps.net/wiki/images/e/ec/Grid2007.pdf
It should be quite easy to convert your logs to the CEDPS format.
Let's read each others papers and then talk more.
Michael Wilde wrote:
> Brian, Suchandra,
> In the Swift workflow system we use a tool (developed as part of the
> GriPhyN Virtual Data System VDS) called "kickstart" to launch programs
> on Grid sites and record their execution environment, exit status and
> resource consumption as an XML document. Kickstart is a simple utility
> runs the real app as a child process and records its info; it usually
> run under GRAM.
> We're now developing some tools to flexibly format and and query this
> info, as its very useful in troubleshooting.
> Ian suggests below that we should integrate this mechanism with a
> CEDPS-defined log format. Ive looked at the CEDPS wiki, but have not yet
> found where this format is defined and how it relates to the myriad
> sources of gird log info.
> Could you point us to some information on this format and how you
> envision that tools like kickstart would integrate with it?
> Any thoughts you have on how we should approach logging in Swift would
> be welcome as well.
> For reference: Swift is described at www.ci.uchicago.edu/swift;
> A sample kickstart record is at:
> http://www.ci.uchicago.edu/~wilde/runs/uc.teragrid/runs/run23/kickstart/angle4-0aac5zgi-kickstart.xml
> A paper on kickstart is at:
> http://www.ci.uchicago.edu/swift/papers/Kickstarting2006.pdf
> Thanks,
> Mike
> Ian Foster wrote:
>> is this format in the "standard log format" that CEDPS defined? I
>> would think it should be.
>>> I started a small perl script to format kickstart records.
>>> For now, for each kickstart output file on the cmd line it prints
>>> one-liners of the form:
>>> Start=2007-09-09T00:24:43.161-05:00 duration=83.993 user=82.470
>>> sys=1.360 machine=i686 host=tg-v050.uc.teragrid.org
>>> but its pretty generalizable.
>>> I did this to find the min, max and stats on run times, looking for
>>> outliers that are holding up the workflow.
>>> If anyone has a similar/better tool please point it out, otherwise
>>> I'll continue to enhance this. Suggestions for a better approach are
>>> welcome.
>>> Pavel (summer student) did something like this in C a while back; I
>>> thought that was added to vds/contrib at that time but I dont see it
>>> in the latest VDS release.  Need to hunt it down.
>>> This perl script is very simple and easy, but rather slow on 1000
>>> kickstart records (need to get timings; Im sure it can be improved,
>>> possibly by grabbing multiple fields on each XPath call.
>>> - Mike
>>> $ cat ~/vds/kix
>>> #!/usr/bin/perl -w -I/home/wilde/vds
>>> #                  ^^^ How to best set the module path?
>>> # Print fields from a list of invocation record xml files
>>> use strict;
>>> use XML::XPath;
>>> use XML::XPath::XMLParser;
>>> while(@ARGV) {
>>>   print_irec(shift @ARGV);
>>> sub print_irec
>>>   my $irec = shift;
>>>   my $xp = XML::XPath->new(filename => $irec);
>>>   my $start = $xp->findvalue('/invocation/mainjob/@start');
>>>   my $utime = $xp->findvalue('/invocation/mainjob/usage/@utime');
>>>   my $stime = $xp->findvalue('/invocation/mainjob/usage/@stime');
>>>   my $duration = $xp->findvalue('/invocation/mainjob/@duration');
>>>   my $machine = $xp->findvalue('/invocation/uname/@machine');
>>>   my $host = $xp->findvalue('/invocation/@hostname');
>>>   print "Start=$start duration=$duration user=$utime sys=$stime
>>> machine=$machine host=$host\n";
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
   Brian L. Tierney,   Lawrence Berkeley National Laboratory (LBNL)
   1 Cyclotron Rd.  MS: 50B-2239,  Berkeley, CA  94720
   tel: 510-486-7381    fax: 510-495-2998   efax: 425-642-4558
   bltierney at lbl.gov   http://www-didc.lbl.gov/~tierney
