[Swift-devel] Re: folding/sequential-while/whatever and accessing data in files
Ben Clifford
benc at hawaga.org.uk
Fri Sep 7 15:48:49 CDT 2007
So I fiddled a little and have this code that works ok:
iterate {
a[foo+1] = countstep(a[foo]);
print("extract int value ", at extractint(a[foo+1]));
} until (@extractint(a[foo+1]) <= 2);
(fully program at the end of this message)
which runs countstep in sequence until a convergence criteria is met.
countstep is simple app which counts the number of bytes in its input file
and outputs that count to its output file (thus converges rapidly to 1)
What is different about this over previous repeat/while statements is
that:
there's an implicitly defined variable 'foo' that iterate{} makes
available for each iteration. In the first iteration, the value of foo is
0, and the value is increased with each subsequent iteration, up to
(Swift's version of) infinity.
there's a function to move from file-content-space to
swift-expression-space (the previously discussed @extractint)
This seems to be the right direction to be going for
fold-like/iteration-like structures.
Full files follow:
$ cat fold2.swift:
type counterfile {}
(counterfile t) greeting(string m) {
app {
echo m stdout=@filename(t);
(counterfile t) countstep(counterfile i) {
app {
wcl @filename(i) @filename(t);
counterfile startfile <"longstartint.txt">;
counterfile a[] <fixed_array_mapper;files="a b c d e f g h i j k l m n o
p q r
s t u v w x y z">;
a[0] = greeting("793578934574893");
iterate {
$ cat wcl
#!/bin/bash
echo $(wc -c < $1) > $2
