[Swift-devel] Re: folding/sequential-while/whatever and accessing data in files
Michael Wilde
wilde at mcs.anl.gov
Fri Sep 7 15:33:53 CDT 2007
Is the retval file being considered, or do people prefer to pull
variables out of files through Swift mapping directives?
It seems to me that a general way to return multiple scalar/list values
of built-in data types is useful and will keep the Swift code clearer.
- Mike
Mihael Hategan wrote:
> On Fri, 2007-09-07 at 19:08 +0000, Ben Clifford wrote:
>> On Fri, 7 Sep 2007, Yong Zhao wrote:
>>> Just want to make a short comment that Ian once mentioned the syntax
>>> int i<"myint.txt">;
>>> should be valid, so you don't need the weird @extractint function.
> You do. The question is where it appears. Should we allow writing
> mappers nicely in Swift?
> intMapper(string fileName) {
> string fileName(): fileName;
> int get(): atoi(read(fileName));
> set(int value): write(fileName, itoa(value));
> or stick to Java:
> IntMapper extends SingleFileMapper {
> DSHandle getValue() {
> return RootNode.newInstance(Types.INT, new
> Integer(readFile(fileName)));
> void setValue(DSHandle val) {
> writeToFile(fileName, String.valueOf(val));
> or do it on the fly:
> int i = @extractint(file)
> Or all of them?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
