[Swift-devel] running MolDyn...
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Sep  7 10:51:45 CDT 2007
Alright, it works!  I had to unset my CLASSPATH, I guess it was picking
up some older version of the stubs from elsewhere...
Ioan
Mihael Hategan wrote:
> Looks like some problem with the stubs.
> On Fri, 2007-09-07 at 01:13 -0500, Ioan Raicu wrote:
>> Hi all,
>> I am trying to run MolDyn, and I am getting some exceptions early on in
>> the workflow.
>>> Caused by: java.lang.NoSuchFieldError: DOCUMENT
>>>         at
>>> org.globus.GenericPortal.stubs.Factory.bindings.FactoryPortTypeSOAPBindingStub._initOperationDesc1(FactoryPortTypeSOAPBindingStub.java:31)
>>>         at
>>> org.globus.GenericPortal.stubs.Factory.bindings.FactoryPortTypeSOAPBindingStub.<clinit>(FactoryPortTypeSOAPBindingStub.java:20)
>>>         at
>>> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceLocator.getFactoryPortTypePort(FactoryServiceLocator.java:55)
>>>         at
>>> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator.getFactoryPortTypePort(FactoryServiceAddressingLocator.java:22)
>>>         at
>>> org.globus.cog.abstraction.impl.execution.deef.ResourcePool.createResources(ResourcePool.java:117)
>>>         at
>>> org.globus.cog.abstraction.impl.execution.deef.ResourcePool.instance(ResourcePool.java:77)
>>>         at
>>> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler.doSubmit(JobSubmissionTaskHandler.java:146)
>>>         at
>>> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:81)
>>>         at
>>> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
>>>         at
>>> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:82)
>>>         ... 5 more
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070907/23b2c3e6/attachment.html>
